Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > Oregon Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Oregon Chapter Join Chapter, Leader: Fabmandelux
  #1 (permalink)
Old 03-27-2010, 12:48 PM
trainwrecker trainwrecker is offline
Garage is empty, add now
trainwrecker is starting off with a positive reputation.
hi/wiring ?
i am new to this site and new to owning a 76 ford crew cab.
i live in salem, and i am looking for somebody to fix the wiring mess in my truck. i dont have the time or skill to do this my self so i am looking for a good shop or maybe a privite preson who is good at wiring to help me with this. any info with be a great help to me.
thanks
trainwrecker.
  #2 (permalink)
Old 03-27-2010, 04:27 PM
WarOzz's Avatar
WarOzz WarOzz is offline
1992 Ford F-250
My Garage
WarOzz is gaining momentum as a positive member of FTE.
If I was closer I would give you a hand... what type of problems are you having and are you talking under the hood electrical, interior or lighting problems?
__________________
Ed - Lincoln City, Oregon - Oregon Chapter Member | Join Our Chapter Here
Machinist/Programmer - Jim Meyer Racing Products
1992 F250 S-Cab 4wd 7.3L IDI ZF5 - Straight Pipe, Ram Air, IP Turned Up, Bi-Xenon 6k HID Lights in Clear Euro Lenses.
1975 F250 Camper Special - Soon To Be Transformed!
  #3 (permalink)
Old 03-27-2010, 04:33 PM
i am having lighting trouble mostly. out of all the fueses in the box under the dash only 2 have power to them and the only thing that does not work is the break light. so i just cant figure out how everything else is working. and it seems to be mostly stock wiring and not all hacked up.
  #4 (permalink)
Old 03-27-2010, 05:13 PM
Old93junk's Avatar
Old93junk Old93junk is online now
Old, tired and grouchy
1993 Ford F-250
Old93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputation
Check the grounds..........In older trucks, they are very suspect.
__________________
93 F-250HD SC 460 E4OD
96 Explorer Limited 4.0 V-6 OHV
93 Ranger Splash 2.3 5spd only 51,000 miles!
84 Ranger 4x4 2.8 V-6 5spd......450,000 miles, now on a brand new 2.8
Dave
Oregon Assistant Chapter leader: To join the Oregon Chapter, click HERE
  #5 (permalink)
Old 03-27-2010, 09:57 PM
StevenhF100's Avatar
StevenhF100 StevenhF100 is offline
1965 Ford F-100
My Garage
StevenhF100 is starting off with a positive reputation.
Quote:
Check your emergency flashers, if they don't work either there is a fuse in the box that operates both. Bottom right fuse if I remember correctly, but should be labeled. Mine on my 76 was very corroded, had to scrape the contacts clean to get it to work.
  #6 (permalink)
Old 03-27-2010, 10:09 PM
i will be checking that fues in the moring because the flashes dont work. tanks for the info.
  #7 (permalink)
Old 03-28-2010, 08:52 AM
WarOzz's Avatar
1992 Ford F-250
My Garage
On the old trucks the majority of lighting goes through the headlight switch... hence the reason it fails so often... to much power goes through it.
As for the brake lights check the fuse as previously stated, take some light sand paper and clean the fuse contacts while your at it. On these older trucks the tail light grounds come off the body so it is very important that the engine to body ground strap is clean and connected properly.
__________________
  #8 (permalink)
Old 03-29-2010, 06:40 AM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
"the only thing that don't work is the brake lights"
Brake light switch is on the brake peddle under the dash. Prone to failure........ Should have power to one side if the fuse and wiring is ok. If there is power at the switch and the switch itself works the problem is most likely in the turn signal switch. Another common problem.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
