Would Cherry Bombs drone in the cab?
I need to do something with my '96 Bronco's exhaust because the weld broke between the muffler exit and the tailpipe. My criteria for the repair are: DIY, cheap, retail parts. I just clamped a straight pipe on my '95 with a 302 when it's muffler rusted away. It wasn't very loud at all outside the truck - actually a nice, quietish rumble and nothing at idle - but it really droned inside the cab on the highway.
For the '96 w/351 I'm thinking about getting a cherry bomb from AutoZone ($22.99 IIRC). This truck has the bigger motor but being a '96 it has the dual cats so I don't know what effect those two differences are going to make, whether louder from more cubes or quieter from more plumbing. I'm not looking to get more HP or nicer sound. All I really care about is whether or not this will make it louder inside the truck on the interstate. Not that it's exactly a tomb at 65MPH in an old Ford but why make it worse?
EDIT: DOH! just realized this one was supposed to go in the Big Bronco forum. If a mod could move it that would probably be good otherwise oh well.
If you run the glasspack with the stock cats it will sound good. It will have a mild tone. Actually this is my prefered type of muffler to run with cats. You will be able to hear it inside the truck but it shouldn't be bad and not much drone. It will be mellow though. Keep the tail pipe, don't dump it.
I finally got the glasspacks installed and I think I'm going to like this setup. I was worried because they are a little dramatic around town. Although it's not loud at all I can definitely hear more of the engine noise from behind me than in front. It's like a nightmare where a 351 is sneaking up on me but it never quite catches me.
Once I got out on the interstate and up to cruising speed it's actually pretty quiet. I'd say that at 55+ there's only a small increase in volume versus the standard type muffler. Also, the sound I do get - both in town and on the interstate - is more of that sweet V8 burble and not a maddening drone.
Thanks again for all the comments.
