symptoms of a crack head - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Old 01-26-2003, 12:15 AM
AbadDriver AbadDriver is offline
AbadDriver is starting off with a positive reputation.
Question symptoms of a crack head
Hey I just wanted to know the symptoms of a cracked head. can anyone give some info?
Old 01-26-2003, 11:21 PM
Bronco2guy Bronco2guy is offline
Bronco2guy is starting off with a positive reputation.
Running rough or sporatic overheating can be obvious clues. A mysterious loss of antifreeze with no apparent "leak" should REALLY be investigated. If you pull your oil dipstick and it looks milky and/or is overfull then that is a sign that you have water in your oil (which most likely came from your cooling system via blown head gasket or cracked head). If it DOES show overfull, let it sit for a while (all the water will separate from the oil and drain to the bottom of your oil pan) and then loosen the oil drain plug until fluid starts dripping out. If the fluid is water then you can pretty much bet on a cracked head or at least blown gasket. If you have access to a pressure tester you can see if your cooling system is losing pressure (with no sign of an obvious leak) or there is also a test that involves some special chemicals that will turn different colors if there are exhaust gasses in your cooling system. I am not sure if there is a way to tell the difference between a cracked head or block and a blown head gasket except to tear it down and look, but that doesn't necessarily mean that there ISN'T a way....I just don't know of one. Hope this helps.
Joe
Old 01-27-2003, 12:48 PM
az_ford_man az_ford_man is offline
az_ford_man is starting off with a positive reputation.
I just finished a friends Bronco II with this problem. He was losing coolant, but there was no apparent external leak. The first thing I did was rent a radiator pressure tester and test the system which would tell if there was a blown head gasket or crack in the head in the cylinders. IF there is a blown head gasket or crack, there will be bubbles in the coolant when the engine is running, and also when the tester is on the radiator, the pressure in the cooling system will rise.
Another thing to look at is the spark plugs. Crank the engine over with the coil wire grounded, and the remove the plugs. check and see if they wet with coolant.
If you have access to a compression tester, run a compression check on all the cylinders ( described in repair manual) If there is a reading on two adjacent cylinders are 20 pounds or lower than the other cylinders, there is a possibility of a blown head gasket.
If you are experiencing coolant loss and al the other things check out, consider the Intake manifold is leaking coolant into the intake for that cylinder. ( personal experience ) That is what was happening on the above mentioned Bronco. Once a new intake gasket was installed, and the manifold tourqued down, there was no more problems.
Hope this helps.
Old 01-27-2003, 05:21 PM
the only reason i ask is because i can smell gas in my oil and loss of power, stalls out or blows clouds of white smoke. and my MPG is around 6
Old 01-27-2003, 06:25 PM
Avanti Avanti is offline
Avanti is starting off with a positive reputation.
What your Bronco do you have? sounds like a fuel leak. If you have a mechanical fuel pump the gas may be leaking thru the internal diafram. If you have fuel injection it could be thru the fuel pressure regulator. ???
Old 01-27-2003, 09:38 PM
How many miles are on the engine and what year is it? Carb or fuel injection? First thing I would do is a compression test on the motor. Might be blowby past the rings, letting the air/fuel mixture into the crankcase. After you do the inital test, write down the readings for each cylinder, then squirt some oil in the cylinder, and do the test again. If there is a differance in the two readings, then you need to rebuild the engine.
My .02
Rod
Old 01-27-2003, 09:49 PM
mines an 86 2.9l dont know how many miles on either body or engine. is there a way to test the FPR?
Old 01-28-2003, 08:37 AM
Disconnect the vacum line that goes into it. Check for drops of gas. When mine went out the car was hard to start at times & when it did blew out blue smoke out the exhaust after starting.
Old 01-28-2003, 08:38 AM
Old 01-30-2003, 02:31 PM
fordtrucksforever fordtrucksforever is offline
fordtrucksforever is starting off with a positive reputation.
A very easy way to confirm the head(s) being cracked is to slowly remove the radiator cap when motor is at normal temp. If there is little or no pressure or even a release of vacuum, then its reallity.
Fuel Check Valves HD Rider 1999 - 2003 7.3L Power Stroke Diesel 5 12-05-2010 11:01 AM
Oil in coolant? Troy77+79 Modular V8 (4.6L, 5.4L) 6 05-16-2010 11:10 AM
Cracked Front Cover, How Common? origcharger 1999 - 2003 7.3L Power Stroke Diesel 4 12-30-2009 08:30 PM
cracked head? beaverplt 1987 - 1996 F150 & Larger F-Series Trucks 4 05-08-2007 04:58 PM
What are symptoms of blown head gasket? mgazak 1997 - 2003 F150 5 10-31-2002 10:15 PM
Tags
1995, blue, bronco, car, coolant, crack, cracked, crackhead, engine, f150, head, heads, signs, smoke, symptom, symptoms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
