TOW HAUL LIGHT FLASHING - Ford Truck Enthusiasts Forums
Old 03-27-2010, 11:28 AM
Delawhere?'s Avatar
Delawhere? Delawhere? is offline
Delawhere? is starting off with a positive reputation.
While in Florida on vacation, we were driving on I-75 when the Tow/Haul light began flashing, and the trans downshifted to a lower gear and stuck there. It wouldn't shift at all, even after coming to a stop and shifting in and out of gear. When I would take off it felt like it was in 4th or 5th gear and the idle speed was higher than normal when stopped also. We drove to the nearest Ford dealer and dropped it off. Turns out it was a SHIFT SELENOID, and they also replaced the INTERNAL TRANS HARNESS, along with the 2 filters and oil. Many posts on FTE have been about the TEMP SENSOR but not many on the SELENOID so I thought I would post this so others may take note if this should happen to them. Thank heavans for my extended warranty, this would have cost me $733, instead I only paid the deductible. I figure I'm ahead of the game, as the extended warranty cost me $1200. in 05, and have had repairs worth over $4000. so far, and still have another year and a half to go.
Old 03-27-2010, 07:10 PM
Maxium4x4's Avatar
Maxium4x4 Maxium4x4 is offline
Maxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputation
Good to hear you were taken care of on the road away from home.
Old 03-27-2010, 07:17 PM
toolman05kr toolman05kr is offline
toolman05kr is gaining momentum as a positive member of FTE.
Thanks for passing on the info, and glad it worked out.
Old 07-29-2011, 08:43 AM
miller45103 miller45103 is offline
miller45103 is starting off with a positive reputation.
Thanks for posting Delawhere?. My truck was acting the ssame way last night, but did some running around this morning and everything ran just fine. No issues. The trans is over the limit for fluid, not sure if that would affect it. Unless if was making the fluid get real hot. Stupid gauge on the dash does not help. SCT will be on the truck soon to monitor it closer.
4R100 Trans OD light flashing, won't go into 4th, and occasionally over heats Slash19 1999 - 2003 7.3L Power Stroke Diesel 10 04-11-2016 05:15 PM
2011 F-350 trans issue CDNMuddawg 6.7L Power Stroke Diesel 7 09-18-2015 07:26 PM
Couple concerns with my purchase ezduzit01 6.7L Power Stroke Diesel 15 05-20-2014 03:40 PM
2003 6.0L Tow/Haul Lights Flashes Freedom0115 6.0L Power Stroke Diesel 14 03-10-2014 09:12 AM
I think I blew my trans Larry85355 6.0L Power Stroke Diesel 11 11-03-2012 04:30 PM
Tags
07, 2004, 2005, 60, 99, diesel, f150, f250, f350, flashing, ford, haul, light, tow, towhaul
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
