failed nj emissions test - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
Old 03-27-2010, 05:58 AM
crankoldman crankoldman is offline
crankoldman is starting off with a positive reputation.
Unhappy failed nj emissions test
I have a 2004 v10,i went for my inspection and they told me i failed the idle test.I went to an indepent nj inspection station after that and he told me it was most likely the banks chip i installed in the truck about 4 years ago.I have the complete banks system from a to z,which is rated 50 state legel.Can any one help with this problem, can i send the chip back and have it checked?
Old 03-27-2010, 04:43 PM
Antelope V-10 Antelope V-10 is offline
Antelope V-10 is starting off with a positive reputation.
Just looking for some more info. Why didn't it pass? Tail pipe emissions to high? Tech saw the Banks chip and failed it?
Old 03-28-2010, 04:01 AM
tail pipe emissions,idle test.
Old 03-28-2010, 11:55 AM
OK. Have you had any CEL or codes recently? Done any tune up work? IE clean MAF, replace air fliter, plugs and boots?
Old 03-29-2010, 03:59 AM
no.truck only has 43,000 miles only work done was banks system. truck is not used for city driving ,only used to tow travel trailer.
Old 03-29-2010, 11:06 AM
I would clean the MAF, then take the Banks chip off and see if it will pass. I'm not sure how you would do that. If you have your install instructions it should say. If I remember right the Banks is an add-on type chip. If it does pass, then contact Banks to see what they say.
Old 03-29-2010, 02:18 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
You have to find out WHY it failed the idle test. It will have both HC and CO values. If you have them, post them, AND the limits.
i hope someone can answer my question twall_SD250 New Jersey Chapter 1 10-22-2013 06:34 PM
2001 Windstar OBD NJ Inspection Trouble adg8165 3.8 & 4.2L V6 0 03-19-2012 06:17 PM
NJ FTE members re: self-inspection jlalanas 6.4L Power Stroke Diesel 1 09-09-2010 05:18 PM
window tint dutydave 1999 to 2016 Super Duty 8 07-24-2008 09:39 AM
diesel emissions testing in NJ? beagledog Bio-diesel, Propane & Alternative Diesel Engine Fuels 4 12-27-2006 03:45 PM
Tags
1996, 50, emission, emissions, f150, failed, ford, hc, high, idle, jersey, nj, ranger, test, testing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
