cleaning EBP sensor
03-26-2010, 06:34 PM
on
cleaning EBP sensor
How to you clean the EBP sensor?
03-26-2010, 07:43 PM
on
03-26-2010, 07:45 PM
You clean the wiring connectors.. and eliminate bad connection as a cause.
03-26-2010, 07:50 PM
The most common issue is a plugged tube. It is pretty straight forward to remove and clean.
03-26-2010, 08:30 PM
to clean the tube a some copper core wire does a good job. or if you have an old speedo cable laying around works even better.
03-26-2010, 09:12 PM
I uninstalled both the sensor and the tube. Cleaned the tube with compressed air, and then cleaned both with MAF cleaner. Worked great.
bigreentruck
12-13-2016 12:37 AM
Iaff113
09-11-2014 01:58 AM
waterboy_fishing
04-25-2012 10:33 PM
rdunagan
03-04-2011 09:25 PM
rosa70
38
09-04-2005 03:21 AM
1996 ,
60 ,
60l ,
back ,
bad ,
clean ,
cleaning ,
diesel ,
ebp ,
evp ,
exhaust ,
ford ,
powerstroke ,
pressure ,
sensor
