Installed '05-'07 Lariat Woodgrain Dash Panel & Navigator wheel in my Excursion - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 07-13-2010, 02:26 PM
hkaiser83 hkaiser83 is online now
hkaiser83 is gaining momentum as a positive member of FTE.hkaiser83 is gaining momentum as a positive member of FTE.
I just did this conversion myself and I found a very easy work around for the defroster switch. My Excursion doesn't have a backup sensor and the backup sensor harness and defroster switc harness are almost completely identical. I made a very minor modification to the plug itself and plugged it right in. Works like a charm.
  #32
Old 07-13-2010, 06:50 PM
RMBC Freeride's Avatar
RMBC Freeride RMBC Freeride is offline
RMBC Freeride has a good reputation on FTE.RMBC Freeride has a good reputation on FTE.
Quote:
Nice! Please share your pictures of the conversion.
I appreciate the tip on the Backup sensor switch, but it doesnt help my rig... I have both defrost and parking assist (sensors).
  #33
Old 07-13-2010, 07:37 PM
Haha...now that IS a problem.
I'll take some pictures as soon as I figure out a solution for the stereo mounting situation!
  #34
Old 07-13-2010, 09:55 PM
EXCURSIONATOR1's Avatar
EXCURSIONATOR1 EXCURSIONATOR1 is offline
EXCURSIONATOR1 is gaining momentum as a positive member of FTE.
Did you change your steering wheel? I need to convert mine. It looks horible at 75k
  #35
Old 12-29-2013, 11:04 PM
Finally got a rear defrost switch in place that fits in my 05-07 superduty dash:
And also fitted a USB/AUX hub next to my 12V "Power Point"
Unfortunately, my rear defrost and mirrors STILL DON'T WORK! Grrrr! Looking for help here: http://www.ford-trucks.com/forums/10...2005-eatc.html
  #36
Old 12-30-2013, 02:46 AM
fordboy2's Avatar
fordboy2 fordboy2 is offline
fordboy2 is gaining momentum as a positive member of FTE.
Very nice work been thinking of doing this on my wifes. Gonna be adding power pedals to it soon maybe I will just do it all at once.
  #37
Old 03-12-2014, 07:14 PM
Ladsonselph Ladsonselph is offline
Ladsonselph is starting off with a positive reputation.
So about your headlight switch. I just purchased an 06 king ranch bezel for my 2002 f250 but the headlight plugs are totally different. What do you suggest? And my aftermarket radio isn't large enough for the hole that is provided with the new bezel. What mounting hardware did you buy to go around the radio?
  #38
Old 03-13-2014, 09:45 AM
Quote:
As I recall, the '05 bezel I used plugged right in to my harness. Maybe they changed it in '06. Any chance of using your existing switch and mounting it in place of the '06 switch on that little black panel?
I had to buy a '05-'07 double DIN stereo mounting kit from a stereo shop. Also used parts from a 99'-04' stereo mounting kit too. It was not a plug and play install for sure!
  #39
Old 03-13-2014, 06:42 PM
I noticed lastnight it's quite a challenge! I just absolutely can't figure this switch out. My f250 has two identical sized square plugs for the headlight switch whereas the 2006 switch has a slim rectangle plug for the dimmer and a thick rectangle plug for the headlamps.
7.3 PSD Swap Project into 2005 V10 Excursion Sunline Fan Excursion - King of SUVs 378 08-21-2014 10:20 AM
2.5" Leveling Kit + V/C code Install = 4.5" lift!!! RMBC Freeride Excursion - King of SUVs 42 11-25-2013 03:11 PM
2nd Row Seat swap info: Bench/Buckets (will it work?) RMBC Freeride Excursion - King of SUVs 20 04-14-2012 08:03 AM
Because owning two Excursions isn't enough... Sunline Fan Excursion - King of SUVs 56 12-28-2011 12:18 AM
Finally got my 79 F-250 converted over to a Diesel!!! Pics inside~ Ford428CJ FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 10 11-24-2007 08:42 PM
Tags
07, 2002, 2005, console, excursion, excusion, ford, grain, kit, lariat, navigator, rear, wheels, wood, woodgrain
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
