need help figuring out what this is - Ford Truck Enthusiasts Forums
Old 03-26-2010, 05:03 PM
dixiemudder04's Avatar
dixiemudder04 dixiemudder04 is offline
dixiemudder04 is starting off with a positive reputation.
I have a 06 f150 xl. It has aftermarket power windows/ locks. I was under the dash and came across this.....
The pic on the left is a close up of the part in question. The pic on the right is the power windows and doorlocks and the part in question. There is also and toggle switch with grey/white and grey wires coming out it.
Old 03-26-2010, 05:47 PM
fordsd350's Avatar
fordsd350 fordsd350 is offline
fordsd350 is starting off with a positive reputation.
Any chance that it's an aftermarket security system with the toggle switch disabling the starting system? The red LED taped to the "box" looks like it would be a dash mounted light indicating the acitivation of the alarm system. But that's just a wild guess.
Have you repositioned the toggle to see what it does to your truck's operation?
Old 03-27-2010, 05:25 PM
the switch does not mess with the way the truck runs. I can start it and ride down the road, turn it on and off and nothing happens that im aware of
Old 03-28-2010, 01:17 PM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
Two fuses and an LED sure looks like an alarm system. The toggle may be the valet switch, or possibly a disable of some kind.
Old 03-28-2010, 01:18 PM
Marine5811's Avatar
Marine5811 Marine5811 is offline
Marine5811 is gaining momentum as a positive member of FTE.
My wife's 4Runner has a box kind of like that. It receives the signal from her key fob for unlocking and locking the doors. It sits under our front passenger seat.
Old 03-30-2010, 05:19 AM
if it's a keyless entry, how in the world would i find out what brand it is so i could get a remote?
Old 03-30-2010, 02:10 PM
Marine5811's Avatar
Sheesh. I'm not sure. I'm sure you've looked all over the thing, so looking on the box itself for a brand name would proabably be a stupid suggestion. It's hard to say because my stupid internet browser won't bring up the pictures you posted of it. I hate to suggest a dealership for anything, but maybe they'll have an idea. Used car dealerships probably run into aftermarket gear all the time. I wish I could be more help but I just don't know.
Old 03-30-2010, 03:49 PM
ReAX's Avatar
The good news is there are only a handful of manufactures, just every manuf has hand fulls of names. Can you take a good picture of the bar code label. There may be a part number or a bit of information someone recognizes If all else fails, start with calling Directed (DEI), give them the numbers on it and see if can provide you with any info.
Old 03-30-2010, 04:39 PM
After doing some fcc id searching. It is a audiovox model alk10 keyless entry. So now i have to figure out where to get remotes and make sure everything is hooked up right because there is a red and black while that has come loose from somewhere
Here is another picture of it, the white plug is 2 different ones
Old 10-19-2010, 08:28 PM
macattack macattack is offline
macattack is starting off with a positive reputation.
Sometimes on those kits you don't use all of the wires, so they may just not be needed. I will talk to my buddy that puts that kind of stuff in for a living to see if he knows where to get a replacement remote
Old 10-30-2010, 10:01 AM
he told me most of the basic audiovox remotes should work but you will hace to take it to a shop to have it programed.
Factory spotlight 64yF100 1961 - 1966 F-100 & Larger F-Series Trucks 2 05-16-2010 12:07 PM
My warn hub caught fire... 5.4L to Freedom 1999 to 2016 Super Duty 58 11-30-2009 06:04 PM
exhaust question dixiemudder04 North Carolina Chapter 22 08-24-2008 09:32 AM
need some help with a part dixiemudder04 Cooling, Heating, Ventilation & A/C 5 03-03-2006 05:09 PM
pics in gallery dixiemudder User Gallery & Picture Display 2 10-06-2004 08:25 PM
Tags
alk10, audiovox
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
