The AIHDWI Mod
The dribble is not a concern when the engine is running, but I've seen others suggest mounting the nozzle in the CAC pipe where it will allow any water that could trickle in with engine OFF to run down into CAC instead of on top of a piston.
With good tuning and no boost/drive-pressure leaks, EGT's are not a problem with stock injectors.
WI Parts List
Tank
250 psi shurflo water pump
6.2 GPH nozzle (this is what I have)
12.2 GPH nozzle for engines with more HP (they are 1/8"
NPT)
Tee (if you are using 2 nozzles)
1/8" NPT X 1/4" hose barbs
Hose barbs that will fit the pump you buy
Metal check valve 1/4" NPT F ports
20 feet of 1/4" OD (.180" ID) poly hose
a little 1/4" ID poly hose to connect .180" and the 1/4
hose barb
Boost switch (0-25 psi is what I have)
Wiring
Fuse
Switches and LEDs
Tank
NPT)
hose barb
Wiring
Fuse
Switches and LEDs
I'm really just regurgitating some of what I've read on the 'net. The truth is YOU are my go-to guy on this subject!!
Another tidbit I took away from my 'research' was it may not be a bad idea to use a water-based cutting oil in the water to mitigate corrosion in the intake chambers.
redlightning93
Ford Truck Parts for Sale
19
10-26-2015 09:06 PM
kirkharrod
53
01-26-2011 06:28 PM
