Intermittent engine cutout - Ford Truck Enthusiasts Forums
Old 03-25-2010, 07:30 PM
Kilo Sierra Kilo Sierra is offline
Kilo Sierra is starting off with a positive reputation.
Howdy! 1978 F-150 with 400M. Engine runs like a champ (when it's running!) Edlebrock carb and manifold, headers. Fresh rebuild with zero issues for about 13000miles/1 year. Everything is tight. Fuel is clean. No fuel delivery issues. Carb is properly adjusted, to include electric choke. Ignition switch NOT loose or any hanging wires.
PROBLEM: After warm-up while driving under normal conditions, engine will die for apparently no reason. All electrical items are still working (lights, radio, etc). Pull over, put in park, immediately starts right up and runs. Will continue to do it all the way home. Daughters daily driver so this is unacceptable.
Sat in the garage with engine idling after warmup, wiggled ignition switch to no effect. Disconnected duraspark, engine dies. Reconnect, immediate start-up.
Any assistance would be greatly appreciated.
Old 03-25-2010, 09:08 PM
ctubutis's Avatar
ctubutis ctubutis is online now
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
This is a classic symptom of a dying DuraSpark module; take it (the DS2 module) to an
auto parts store to be tested.
Old 03-25-2010, 09:39 PM
firstonraceday's Avatar
firstonraceday firstonraceday is online now
firstonraceday is gaining momentum as a positive member of FTE.
Second on the DS module. Another possibility is a dying magnetic pickup in the distributor. Both exhibit the same symptoms.
Old 03-25-2010, 10:31 PM
Appreciate the info...I start with the DS2, and keep the magnetic pickup in mind also.
Greatly appreciate the help.
ks
Old 03-26-2010, 09:37 PM
vtjvt's Avatar
vtjvt vtjvt is offline
vtjvt is starting off with a positive reputation.
Had the same problem on my 78 F150, just changed the control module and pickup coil 2 hours ago, Problem solved
Old 09-14-2012, 04:07 PM
hayden01's Avatar
hayden01 hayden01 is offline
hayden01 is starting off with a positive reputation.
I have the same problem with my '76 302 in my '84 Bronco were it dies randomly and in the most inconvenient places (turn lanes, middle of intersections, petrol stations, etc... picky girl she is. I swear when she does that sometimes shes laughing).
The Duraspark II ignition module is a gray box with 6 wires coming out of it yes?
Mainly does it when the engine is cold and warming up to operating temp but also does it when the engine is warm to. And also the ignition module gets really hot, almost to hot to touch sometimes, is that normal?
Last edited by hayden01; 09-14-2012 at 10:24 PM. Reason: wow im daft... I answered my own question...
200ci Starts, warms up, dies. lowridaz22 Ford Inline Six, 200, 250, 4.9L / 300 3 11-09-2015 12:11 AM
Cycling Oil Pressure '92 5.8 jbsman0048 1978 - 1996 Big Bronco 2 06-02-2015 07:24 PM
Engine wont start, cranks, wants to start, need some diagnostic advice brain75 1948 - 1956 F1, F100 & Larger F-Series Trucks 41 10-03-2011 10:35 AM
F250 misfire, wet engine? DougNC 1999 to 2016 Super Duty 8 01-05-2011 02:53 PM
Holly 4 barrel carb adjustments steve m Fuel Injection, Carburetion & Fuel System 9 02-07-2005 11:10 PM
Tags
400, 78, choke, code, cutout, dying, engine, f150, ford, intermittent, warm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
