Location of ECM? - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Location of ECM?
Old 03-25-2010, 06:51 PM
5. Slow 5. Slow is offline
5. Slow is starting off with a positive reputation.
Location of ECM?
Hi all,
I have a stupid question, where is the ECM located? I bought a used Hypermax chip for my truck and I need to get it re burned. I was asked for the code off of the computer and I have no idea where it is at. Thanks
Old 03-25-2010, 06:59 PM
fordpride's Avatar
fordpride fordpride is online now
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
it's in the fire wall look uder the brake booster and it's the wiring harness closest to driver fender
Old 03-25-2010, 07:14 PM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
To pull the computer out you need to pull back the plastic fender liner and loosen the 10mm bolt holding the wiring connection to the PCM. I have no idea if you can read the code sticker on an OBS w/o pulling the PCM.
Old 03-25-2010, 07:21 PM
fordpride's Avatar
i f you take the harness of the PCM you can see it with a mirror and a lite but i think the inner fender has to move to get the harness out of the way to see the code
Old 03-25-2010, 07:23 PM
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
Quote:
What the hell do you know about the OBS ....
the numbers on the PCM are visible with out removing it ,, you will need a mirror ....
Old 03-25-2010, 07:37 PM
Ok. So grab a mirror, pull the plastic fender well out and I should be able to read the code. Thanks guys
Old 03-25-2010, 07:39 PM
fordpride's Avatar
i just looked at mine just get a mirror and lite and look by the harness on the driver side and you shoule be able to see it
Old 03-25-2010, 07:48 PM
Quote:
You don't need to do anything , cept for the mirror ...
Old 03-25-2010, 07:50 PM
Quote:
I had 2 OBS gassers ya know, I know a thing or two. I've worked on an OBS PSD before, and I stayed at a Holiday Inn Express last night so I'm pretty well set!
Old 03-25-2010, 07:52 PM
....LOL.....
Old 03-25-2010, 07:58 PM
OK guys i might be slow but is the ecm # on the black trim that holds it into the firewall or the ford tag wrapped on the wiring harness?
Old 03-25-2010, 08:12 PM
fordpride's Avatar
this should help find where the # is http://corporateabuse.net/wp-content...ter-inside.jpg
Old 03-25-2010, 08:24 PM
It was really easy to find. Thanks
ECM Location Amish Ford 1997 - 2003 F150 3 12-04-2015 06:11 PM
Ford e150 ECU location coolfeet 1968-2013 Full Size Vans 7 07-02-2013 10:00 PM
ECM Location on a 99 F350 BuddhaKat 1999 to 2016 Super Duty 6 07-05-2011 05:24 PM
ECM location renchr56 1968-2013 Full Size Vans 4 01-12-2011 01:44 PM
Location of ECM Johns9163 1997 - 2003 F150 6 03-07-2005 07:46 PM
Tags
1994, 2008, 97, diesel, ecm, ecmpcm, f150, f350, ford, location, obs, pcm, powerstroke, psd, truck, wheres
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
