Maual primer on fuel pump? - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 07-17-2010, 04:44 PM
Rick Wallace Rick Wallace is offline
Rick Wallace is gaining momentum as a positive member of FTE.
Ok,,Ill redo it when I get to that point..Thanks
  #32
Old 07-17-2010, 06:55 PM
Otahyoni's Avatar
Otahyoni Otahyoni is offline
Otahyoni has a good reputation on FTE.Otahyoni has a good reputation on FTE.
Quote:
Originally Posted by Marianna2003 View Post
At the bottom of Post#8 that's the one I recommend.
See? I knew i heard that somewhere...
  #33
Old 07-17-2010, 08:55 PM
Marianna2003 Marianna2003 is offline
Marianna2003 is gaining momentum as a positive member of FTE.
These pumps only draw 3-4 amps. The electronics energizes a coil that pulls the plunge against a spring allowing fuel to flow through the hollow plunger. the valve in the end of the plunger then closes sand the spring pushes the fuel out of the pump. If they are deadheaded, the plunger will try to cycle but it can't move leaving the electronics uneffected. Running them dry could damage them since the plunger will cycle without lubrication or cooling.
The switch from Summit is a 3 prong, 3-5 psi switch. It has a common and anormally open and a normally closed contact. GM uses them on their EFI engines for the idiot light and fuel, pump control. A junkyard item if you're short on cash.
If you are concerned about saving power by removing the MFP, it only uses about 0.0004 HP to pump 0.1GPM at 7 PSI. The electric will take about 0.06 HP to do the same job. Just a thought!
As I've said before, you don't have to eliminate the MFP. If you mount the EP between the MFP and the EP you will not push fuel into the crankcase.
  #34
Old 07-18-2010, 06:40 PM
daman_55 daman_55 is offline
daman_55 is starting off with a positive reputation.
I have mines wired in to the fuel shut off plug in .
  #35
Old 08-12-2010, 10:11 AM
n2ohatch n2ohatch is offline
n2ohatch is starting off with a positive reputation.
do you leave the electric pump running all the time of just to prime the IP at start up??
  #36
Old 08-12-2010, 11:56 AM
Brad Leroy's Avatar
Brad Leroy Brad Leroy is online now
Brad Leroy is starting off with a positive reputation.
I just hit mine when starting up and run it only until the motor catches, then turn it off - only 15 seconds or so seems to do the trick.
  #37
Old 08-19-2014, 06:43 PM
tailgateresponseunit tailgateresponseunit is offline
tailgateresponseunit is starting off with a positive reputation.
Back from the dead
I am looking to complete a setup similar to that in post #8 on my e350 with a 7.3 idi that has had air intrusion issues since I purchased it.
I will be the first to admit that I don't know the 1st thing about working on a diesel motor...with that ignorance, I am trying to get some input on what the line which is now connected to the auxiliary pump in post 8 was originally leading to. Any help is much appreciated.
  #38
Old 08-19-2014, 07:50 PM
Macrobb's Avatar
Macrobb Macrobb is offline
Macrobb is gaining momentum as a positive member of FTE.
I still don't see why not just put a check-valve on the intake side of your water separator... it solves all these problems without adding another electronic/electric piece to fail.
  #39
Old 08-19-2014, 07:56 PM
ozdatman's Avatar
ozdatman ozdatman is offline
ozdatman is gaining momentum as a positive member of FTE.
Quote:
Can you give us a picture of where you put yours. I bought a primer bulb but I'm unsure where to put it.
  #40
Old 08-19-2014, 08:21 PM
Macrobb's Avatar
Quote:
http://robbiethe1st.afraid.org/image...140723_006.jpg
The rubber hose comes from the mechanical fuel pump, through that squeeze-bulb, and then into the intake of the separator.
  #41
Old 08-20-2014, 01:05 AM
ozdatman's Avatar
Cheers for the pic.
So you got rid of your metal line altogether?
  #42
Old 08-20-2014, 07:39 PM
Macrobb's Avatar
Cheers for the pic.
Either that, or just whack it down near the pump and use that end as a fitting -- slip it into hose.
I'm actually not sure on this rig; it was already converted to rubber hose by the PO; I just added the squeeze-bulb.
I've replaced the other side with rubber as well, actually(filter to IP), but that's very recently.
starting my restoration fordf2501 1999 to 2016 Super Duty 29 03-24-2017 07:30 AM
Spray can primer or shop primer? mad103 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 01-30-2016 02:28 PM
Primer question.... avf100 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 08-14-2013 05:25 PM
What causes spray paint to "crack" or wrinkle? ghunt Paint & Bodywork 5 03-22-2010 07:43 PM
Primer Paint Job sleep_deprived129 Paint & Bodywork 17 02-21-2008 05:51 PM
Tags
2005, 250, 60, 73, air, diesel, f150, ford, fuel, leaking, loses, manual, prime, primer, pump
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
