Maual primer on fuel pump? - Page 2 - Ford Truck Enthusiasts Forums
Old 05-19-2010, 01:15 AM
Brad Leroy's Avatar
Brad Leroy Brad Leroy is offline
Brad Leroy is starting off with a positive reputation.
Quote:
Originally Posted by Marianna2003 View Post
You don't have to ditch your old pump. You can do like I did as follows:
I finally got around to installing a system like this and no more problems! I have it on a hard switch, so once she's up and running, I just turn the pump off. It is such a relief to have this worry taken care of. Thanks for the help, Marianna.
Old 06-18-2010, 07:21 PM
Marianna2003 Marianna2003 is offline
Marianna2003 is gaining momentum as a positive member of FTE.
Glad I could help!
Old 07-17-2010, 02:45 PM
daman_55 daman_55 is offline
daman_55 is starting off with a positive reputation.
i installed the same pump got it from oreilly and they said the o-rings cant handle the diesel so i took it off and installed a mr gasket one. i have it set up the same way and have the hot wire going to the injector pump plug in. do i need to do anything else to it
Old 07-17-2010, 02:53 PM
kenpobuck's Avatar
kenpobuck kenpobuck is offline
kenpobuck is gaining momentum as a positive member of FTE.kenpobuck is gaining momentum as a positive member of FTE.
Any electric fuel pump should be run through a relay and have an inertia shut off switch. If you are in an accident it will continue to push fuel unless you shut it down.
Old 07-17-2010, 02:59 PM
ok thats the next thing i'll do
Old 07-17-2010, 03:40 PM
kenpobuck's Avatar
The relay is because of the amp draw of the electric pump. It will fry a switch if hard wired ( don't ask how I know lol).
Old 07-17-2010, 03:45 PM
Otahyoni's Avatar
Otahyoni Otahyoni is offline
Otahyoni has a good reputation on FTE.Otahyoni has a good reputation on FTE.
Will this guy work? Airtex E8012S - Electric Fuel Pump | O'Reilly Auto Parts
I heard to recommended somewhere...
Old 07-17-2010, 04:03 PM
kenpobuck's Avatar
Should work. The pressure is about right. But I can't stress it enough to use a relay and inertia switch! I never used to worry about either but last yr I almost burned my truck up with just a switch. Also a buddy rolled his buggy, The engine quit but the pump kept running. It was almost a deadly disater.
Old 07-17-2010, 04:12 PM
At the bottom of Post#8 that's the one I recommend.
Last edited by Marianna2003; 07-17-2010 at 04:27 PM. Reason: Eliminate duplication.
Old 07-17-2010, 04:19 PM
Quote:
That's funny. That pump was developed for the OE on the 5.7 Oldsmobile Diesel jokes. They were adapted to gasoline use by adding a teflon ring on the plunger. Some parts men speak with forked tongue.
Old 07-17-2010, 04:23 PM
kenpobuck's Avatar
Most do!!!!!!!!!!!!!!!!!!
Old 07-17-2010, 05:00 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
careful.i did that for a day,and was told this was bad.very bad(luckily,i knew better to search and ask before i actually started using my truck like that.)it needs to go on a relay,thats to much draw on that line.with the relay,you just use the fss to trigger a hot directly from the battery to the pump,which is also on a fuse.
and ditch that fuel filter for a barbed fitting.not if,but when that little sucker gets plugged,it will burn the pump up in no time im sure.
the black mr.gasket is not rated for diesel fuel either,only the green model #12D is.
http://www.ford-trucks.com/forums/86...-terminal.html
  #28
Old 07-17-2010, 05:12 PM
Rick Wallace Rick Wallace is offline
Rick Wallace is gaining momentum as a positive member of FTE.
XLT, now IM confuised,I have the same pump you do,although mines not running I wired mine into what was the cruse control. Is that bad?
  #29
Old 07-17-2010, 05:15 PM
kenpobuck's Avatar
Yes that is bad. It should be wired thru a relay. The relay will handle the heavier amp draw of the pump and you use the right ga. wire. Puting that much juice thru a regular switch or wireing will fry it.
  #30
Old 07-17-2010, 05:18 PM
Quote:
probably lol.
according to Dave,no matter where you get power,it should be be used to open a relay only,and draw from a line directly pulled from the battery,with a fuse just after the terminal.
perhaps the cruise line is only used for that,and since its not being used anymore it might be ok....i just don't know.
after it was explained to me how to do it,and i see how it works,there's simply nothing better than that setup.- for a fool proof,turn key and go install.
and actually,im not sure if thats a good line to use for your trigger either.doesn't cruise only work at a certain speed,and go off with your brakes? i guess the line where you tapped into it,may be juiced all the time......man,i dunno if i would have picked that line to use for a pump.any rate,you'll probably burn up your cruise switch if you dont put it on a relay,and draw directly from the battery.
you best bet is to just follow how i did it,and then you'll never have to mess with it.just turn the key forward,and it starts pumping/no need for a devoted switch.
starting my restoration fordf2501 1999 to 2016 Super Duty 19 10-25-2016 08:02 AM
Spray can primer or shop primer? mad103 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 01-30-2016 03:28 PM
Fuel Filter Filler Macs1964F100 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 06-25-2014 08:50 PM
Diesel Kleen TampaDave 6.0L Power Stroke Diesel 13 03-19-2013 01:17 AM
power services vs. diesel kleen granny_rocket 1994.5 - 1997 7.3L Power Stroke Diesel 5 02-09-2010 08:14 PM
Tags
2005, 250, 60, 73, air, diesel, f150, ford, fuel, leaking, loses, manual, prime, primer, pump
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
