EXTREMELY rough running after startup, but cleared up? WTF???
hey guys. earlier today i started my truck up coldish(80* oil temp) and it started just fine like normal. i let it start warming up and after letting it run for about 15 seconds of idle time it starting working itself into a slight lope. it has done that for awhile now so i thought nothing of it. well it worked into a small lope like normal, but this time wasn't like other times. normally it will work into a little bit of a lope for a couple seconds then go back to smooth idle. This time it kept loping worse and worse and worse. the engine was popping hard enough that there was smoke just misting out of the stacks pretty good. i took the RPMs up to around 1400 RPM and it just kepting doing this all the way up to 1400 RPM. so i took it up to 2000 RPM and it smoothed out SOME, but not much. looked back and smoke was just about pouring out of the stacks(black smoke), but i wasn't being hard on the throttle at all. just barely touching it.
Let it idle again and unplugged the <ACRONYM title="Injection Control Pressure">ICP</ACRONYM>. the engine popped one good time as soon as i did that and then went right back to being dumb so i plugged it back in. during this whole time <ACRONYM title="Injection Control Pressure">ICP</ACRONYM> appeared to stay normal, but <ACRONYM title="Injection Pressure Regulator">IPR</ACRONYM> DC% was fluctuating between 12-20%. i switched programs on the chip, no change except for idle speed. turned the truck off, then back on about 10 seconds later and no change, it was still idling crappy and smoking slightly. took it out on the street in street race and went to accelerate.. <ACRONYM title="Injection Control Pressure">ICP</ACRONYM> jumped up to 2900psi, but the truck DID NOT move for chit. it was like there was no fuel there. i looked behind me and there wasn't any smoke. so now i'm thinking to myself like what the hell is going on? i switched tanks to the rear tank and let it idle and after about a 20 seconds it started idling smooth(now oil temp is only 128*). so i took off and fed it some of the ole right foot and it took off like a crazy mother just like it normally does and left a trail of black smoke everywhere since i was in my street race tune. drove it a few miles then back to work and it ran perfectly fine. got back to work, switched it to the front tank of fuel again and everything was fine. let it idle for about 5-10 minutes and it idled smooth and revved nicely the whole time i let it sit there idling. so now i don't think it's a front tank problem as i'm not getting that problem now on the front tank. NO <ACRONYM title="Check Engine Light">CEL</ACRONYM> was set this whole time either
I'm wondering if this could be connected to a problem i had yesterday. yesterday i was doing some testing and lugged the engine down in 5th gear @ 1200 RPM and as the boost started to come on it set the <ACRONYM title="Check Engine Light">CEL</ACRONYM> and lost a little power.. Not much power was lost, but i found that the <ACRONYM title="Injection Control Pressure">ICP</ACRONYM> was low(maxing at 2000psi instead of 2600psi), boost pressure was 5lbs lower than normal, and at idle the <ACRONYM title="Injection Control Pressure">ICP</ACRONYM> was higher than normal @ 1000psi. unplugged the <ACRONYM title="Injection Control Pressure">ICP</ACRONYM> and NO change in idle(was idling a little rough, but not bad at all. just could tell it wasn't QUITE right). plugged the <ACRONYM title="Injection Control Pressure">ICP</ACRONYM> back in and pulled the codes and got these--- P1280, P0113, P0478. haven't looked these up yet to see what they were. i turned the truck off and then started it back up again a few seconds later and everything returned to normal. <ACRONYM title="Injection Control Pressure">ICP</ACRONYM> was normal, full power was back, normal boost pressures, and normal idle.
So, any thoughts guys??????
<!-- / message --><!-- sig -->
While that wouldn't surprise me i don't think it minds taking it.. So far it has refused to give up on me??? I've been being nicer to it lately too. nice and easy on it except for the testing i was doing on the econo tune and extreme tunes to take comparisons of pulsewidth, ICP, and IPR DC%.. that's the only time i've been hardish on it lately. haven't even taken it to the drag strip since October, but maybe it overheard me considering racing it at the upcoming event on April 10th???
IDK.... sounds like you spoke to loud and it heard what was coming so it rebeling lol. Track opens April 2nd up here and I refuse to let my truck hear cuz she will get a temper haha. I think that you need a fuel pressure gauge and if you already have one then you need to see what you fuel pressures are when this kinda crap is happening. But idk, if its got no ***** then does it make sense for the truck to have no power. It would make sense on the smoking black side of things but no in the other sense..... My truck acted funny on me the past two days, wonder if they know our plans haha.
i drove it 30 miles back home from work on the tank that it was screwing up on. didn't seem to run quite right. got home, drained the water seperator and got no water in the fuel(drained into a coke bottle and saw no water seperation). i popped the hood and checked the fuel pressure earlier while it was acting up and fuel pressure was the normal 70psi, no fuel or oil leaks anywhere. it's full on oil. everything is good on it. i have a new ICP and pigtail in it and the IPR has new o-rings and all that fun stuff. wonder if it's just sticking real bad, but the P1280 code tells me ICP out of range low or something i think. gotta go back and look again. once i got home i switched tanks as the one i was on is down to 1/4 tank and i never take them down any farther than that so i'm going to put about half a tank in there and see if it runs good on it. I actually can't tell any difference after switching tanks now. it just doesn't seem to be running quite right, but if i floor it then it spools and hauls azz just like normal. @ WOT feels like it has all it's power, but looks like it's building ICP kinda slowly. instead of popping straight to 2600psi in the extreme tune it pops up to around 2200 psi and climbs kinda slowly from there up to 2600psi.
That's weird because in those vid's it was at 2,900 or so. Is it at all possible to get a little air in the hpop when you nail it then let off a dozen times in a row? Mine will seem a little rough for a few seconds then be OK after 'playing'. Your injectors are pretty new, aren't they? If not fill your fuel bowl up with PS to give them a quick clean. Maybe do it anyway, maybe something got into one or two of them?
I strongly doubt the injectors are causing this issue, but i don't think they are in great shape. probably have a differen't problem. maybe the IPR sticking or something, but i haven't diagnosed a sticking IPR yet and don't know how to know if it's sticking or not.
can't upgrade brother unless i decide to go with 180's instead of 160's, but i doubt i will. i can't afford to throw another turbo on the truck yet so i have to stick with smallish injectors or get a little bigger and keep the tunes low til i can get another turbo, but might be awhile. haha
don't think so dude. u know how many ppl have told me that same thing??? way too many and i tell all of them that these injectors are SCREWED and i'm not giving someone injectors that are screwed. i was going to sell a set to Joe, but the poppet valves are all screwed up on them so i can't let myself sell them to Joe and i won't sell anyone these if they are screwed either. i will get another set from Jim and send him these so he can use the good parts for another set of budget builds..
