I am in need of new(er) rims for my 85. no 24s or anything. found some dodge rims 17in $125 for the set . will they fit ? they are 5-5.5 . work truck rims grey . just have to get center caps . hate do it but its the best deal ive found. thanks
bolt pattern is the same, back spacing is probably different, but shouldn't be a problem.but it's kinda something you gotta try before you buy. don't wanna pick up some useless rims
I concur
Ya they should bolt on. From what I've seen the Dodge has the biggest center and Chevy had the smallest. I often switch my rims around on dodges and fords.
