wire loom tubes - Ford Truck Enthusiasts Forums
wire loom tubes
Old 01-25-2003, 08:28 PM
41Clay's Avatar
41Clay 41Clay is offline
41Clay is starting off with a positive reputation.
wire loom tubes
I was thinking about the early 21-A style wire loom tubes that run by the manifold and was thinking that little dudes create a good atmosphere for cross-fire. Has anyone had trouble with these things causing that? I like the way they smooth out the wires, but a smoother idle is much more important to me. Maybe the 6 volts didn't have a cross-fire problem but a 12 volt or electronic ignition may.
Clayton
Old 01-26-2003, 08:59 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
wire loom tubes
Clayt,
That shouldn't make any difference - the voltage to the coil is dropped by a resistor in a 12V system. Actual voltage across the points is only about 4.5v if I remember right.
Those wire looms do cause problems for some guys - mostly age deterioration of the wire's insulation from what I've heard.
Also a consideration is the firing order and how the wires touch each other. I've seen some crossfire trouble without the looms where 1/2 and 8/6 wires contact each other. firing order 15486372
On my '48 driver, I've even slipped plastic loom material between those wires that are prone to trouble. I don't like the look, but it sure saves headaches.
Spark Plug Wire Crossfire? jv2290 1987 - 1996 F150 & Larger F-Series Trucks 9 01-22-2011 01:39 PM
2.3l crossfire? Brett1989 Ranger & B-Series 7 09-25-2008 04:58 PM
Crossfire with new wires and plugs? nalts 1968-2013 Full Size Vans 3 11-11-2004 11:19 PM
CrossFire Dist. Cap? Where to find. Bigiron427 1961 - 1966 F-100 & Larger F-Series Trucks 1 01-27-2003 04:57 PM
weird problem - timing light will not work rebocardo FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 7 01-07-2003 06:28 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
150, 99, cross, fire, loom, looms, truck, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
