Tachometer Problems? - Ford Truck Enthusiasts Forums
Old 03-25-2010, 09:36 AM
banjopicker66 banjopicker66 is offline
banjopicker66 has a very good reputation on FTE.banjopicker66 has a very good reputation on FTE.banjopicker66 has a very good reputation on FTE.
On my '89 F-250 with E4OD, the tachometer goes to zero at idle, and bounces a bit. Where is the tach sensor, and is there a TPS on this thing?
Thanks!
Old 03-25-2010, 10:16 AM
farmert farmert is online now
farmert has a good reputation on FTE.farmert has a good reputation on FTE.farmert has a good reputation on FTE.
The tach sensor is located on the ip gear cover just to the right and behind the oil fill spout. It is the one inch nut with two wires coming out of it. You can remove it anc wipe it clean which might help it, but mot likely you need a new sensor. a Ford only item.
I'm not an auto guy so I can't help on the tps, other than I think it is on the throttle linkage.
Old 03-25-2010, 10:29 AM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.
I believe there is a tps on the E4OD trucks, but I think its called an FLPS(Fuel level position sensor). I'm pretty sure it's on the IP attached to the throttle lever.
Tachometer Install connection to Electronic Ignition BGF100 1973 - 1979 F-100 & Larger F-Series Trucks 10 10-15-2016 10:58 AM
Tachometer bbierschenk 1973 - 1979 F-100 & Larger F-Series Trucks 10 07-07-2015 10:12 PM
Tachometer 19711969 1967 - 1972 F-100 & Larger F-Series Trucks 7 03-22-2015 06:43 PM
V10 tachometer rclarke 1968-2013 Full Size Vans 5 05-25-2014 11:49 PM
Factory Tachometer Question miashley150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 08-22-2013 12:34 PM
Tags
150, 1990, 350, 73, diesel, f350, flps, ford, gauge, problems, rpm, sensor, tach, tachometer, troubleshooting, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
