Removing the Catalatic converter on my 2006 6.0 Liter - Ford Truck Enthusiasts Forums
Old 03-24-2010, 10:03 PM
Awmjr05 Awmjr05 is offline
Awmjr05 is starting off with a positive reputation.
What results will i get from taking the catalatic converter out of a stock exhaust on my 2006 6.0 liter.
Old 03-24-2010, 10:10 PM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
If you have smog inspections, lots of trouble.
Old 03-24-2010, 10:19 PM
Not in Florida
Old 03-24-2010, 10:26 PM
JBARRBQS JBARRBQS is offline
JBARRBQS is starting off with a positive reputation.
removed my kitty and man its awesome sounds like a jet enging driving down the road
Old 03-24-2010, 10:28 PM
i also have a 4 inch down tube silverline exhaust with a 16 inch long 6 inch tip yep sounds great.
Old 03-25-2010, 06:43 AM
cmcowboy's Avatar
cmcowboy cmcowboy is offline
cmcowboy is gaining momentum as a positive member of FTE.
I have a stock exhaust, and purchased a cat delete pipe. I do not know for sure if it helped anything. But when you take the cat off and try to look trough it and you cannot see any daylight, well it has to help some how??? Muffler delete is next
Old 03-25-2010, 08:10 AM
desertt5 desertt5 is offline
desertt5 is starting off with a positive reputation.
Sell it to someone in Kalifornia. I bet alot of people over there could use one about registration time this year.
Old 03-25-2010, 08:12 AM
SteveBricks's Avatar
SteveBricks SteveBricks is online now
***** Emeritus
SteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputation
Quote:
Originally Posted by Awmjr05 View Post
Not in Florida
Not yet. Better hang on to it if you do take it off.
Old 03-25-2010, 03:26 PM
sweeted's Avatar
sweeted sweeted is offline
sweeted is gaining momentum as a positive member of FTE.sweeted is gaining momentum as a positive member of FTE.
I first installed a muffler delete pipe and noticed a deeper throated big block sound from about 2300 rpm and up.I then deleted the kitty and could then hear a little more of the turbo whistle.Out side of the truck it sounds a little like an F-16.Inside the truck you can hardly tell the difference. I will hang on to the cat and the muffler so if I care to sell the truck later on. I don't live in the middle of nowhere Idaho but I can see it from here. And for the most part this state could give a rats fanny less about the feds.
Old 03-25-2010, 03:36 PM
LaxPlaya21's Avatar
LaxPlaya21 LaxPlaya21 is offline
LaxPlaya21 has a very good reputation on FTE.LaxPlaya21 has a very good reputation on FTE.LaxPlaya21 has a very good reputation on FTE.LaxPlaya21 has a very good reputation on FTE.
Everytime I read posts about the 6.0 exhaust turbo whistle it makes me miss my 2006. I had a MBRP 4" turbo back exhaust with CAT delete. That thing whislted like a 747 preparing for take off... and once you stomped on it sounded like a big block from hell! In my opinion, its the best sounding exhaust noise of any car/truck I have ever heard. I have tried with the 6.4 to replicate the sound... but it just doesn't come close. I have a AFE intake, 4" ceramic down pipe, stock exhaust with cat/dpf delete. It makes some noise, but no real whistle. When I stomp on it that big block noise comes out a little bit.
Old 03-25-2010, 03:54 PM
rocky1074's Avatar
rocky1074 rocky1074 is offline
rocky1074 is gaining momentum as a positive member of FTE.rocky1074 is gaining momentum as a positive member of FTE.
I removed my cat about 3 months ago with a cat delete pipe. You can definitely hear the turbo whistle. I did keep my cat you never know even here in Fl. So if you remove it KEEP IT!!! (Just put the cat to sleep in your garage)
03-07+ Ford 6.0L Powerstroke Diesel Cat Delete Pipe
Old 03-25-2010, 05:31 PM
I wonder if it will help on fuel milage
Old 03-25-2010, 05:47 PM
sweeted's Avatar
not until you get tired of hearing that sweet sound.
Old 03-25-2010, 05:50 PM
BPofMD's Avatar
BPofMD BPofMD is online now
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
It will NOT increase your fuel mileage! If anything, it will DECREASE it....... WHY???? YOU ASK???? Because you will keep your right foot firmly planted to the floor so you can listen to it. You will also wear out your right hand rear window motor running it down so you can listen to it reverberating off the sound barriers!!!!! LOL
Old 03-25-2010, 07:52 PM
mikeast mikeast is offline
mikeast is starting off with a positive reputation.
cat was 90 percent plugged
After reading a thread on this i took it in too buddys shop got him too punch it out , he said it was 90 percent plugged , turbo sounds cooler now better midrange power better highway millage , gonna add banks turboback soon too " waunder how many of these things are plugged without us even knowing lol
6.0 to 7.3 conversion guitarpicr 1999 - 2003 7.3L Power Stroke Diesel 9 12-07-2014 10:33 AM
2006 6.0 liter FUEL INJECTORS dbgphx 6.0L Power Stroke Diesel 15 11-15-2011 11:23 AM
2006-6.0 Liter fan runs on after shut off TravLow 6.0L Power Stroke Diesel 16 02-19-2011 07:37 AM
6.0 liter exhaust brake hlwilkers 1999 to 2016 Super Duty 1 01-30-2011 02:00 PM
How to flush cooling system 2004 6.0 Liter iownbruceville 1999 to 2016 Super Duty 2 12-14-2009 12:34 PM
Tags
2005, 60, cat, catalatic, converter, converters, delete, diesel, e350, f150, ford, removing, romoving, tube, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
