Whats The Best Way To Level Truck? - Ford Truck Enthusiasts Forums
Brakes, Steering, Suspension, Tires, & Wheels Click Here
Old 03-24-2010, 08:40 PM
FlyCool5.0's Avatar
FlyCool5.0 FlyCool5.0 is offline
FlyCool5.0 is starting off with a positive reputation.
Question Whats The Best Way To Level Truck?
1995 F150 5.0 4x4. I hate the front end sagging when the truck is parked on a level spot. Any suggestions on what I can do to level. Buddy suggested poly coil spring spacers?
PLEASE HELP!
Thanks
Old 03-26-2010, 05:32 AM
A1C DiMaggio's Avatar
A1C DiMaggio A1C DiMaggio is offline
A1C DiMaggio is starting off with a positive reputation.
i wouldnt go with spring spacers. i would just spend the little extra money and get lift coil springs. but what you need to know is, depending on how much you lift the front end, you may need taller shocks. spacing the spring will hyper-extend the shocks for long periods of time, causing them to go bad. this will make the front end bounce
Lifting my truck need some input Jarred Perelli 1987 - 1996 F150 & Larger F-Series Trucks 0 07-14-2015 11:17 PM
03 crew cab leveling kit evan1242 6.0L Power Stroke Diesel 2 07-06-2015 03:46 PM
2000 f350 7.3 lift suggestions Melendez7.3 1999 - 2003 7.3L Power Stroke Diesel 7 01-05-2015 08:13 PM
Leveling Kit ( What's the difference ) Miller 2009 - 2014 F150 1 01-21-2014 09:26 PM
1989 2"level kit and bushwacker flares/what size tires chogue 1987 - 1996 F150 & Larger F-Series Trucks 9 08-17-2012 04:09 PM
Tags
2009, 2010, 2011, 2012, end, f150, f250, ford, front, level, leveler, truck, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
