Rear Main Seal is Leaking
I had some small oil leak & I found out that my rear main seal is leaking on the V10.
Has anyone had this problem? Is it expensive to fix? from what I understand you have to drop the tranny to get to it.
Geez
I had 2 technicians, 1 of them a ford tech take a look at it and they both said it was the rear main seal.
Its leaking slowly, and when idling in park you can smell the burning oil because it drips directly on the exhaust.
Geez
I just had my rear main seal repaired under the diesel warrenty. Service tech said it would have cost me about $2300 had it not been under the PSD warrenty and I had to pay for it myself.
They had to pull the engine out of the truck. Tranny, radiator, engine, fans, etc...they all came out.
I went to the dealer to check on it before they were done putting it all back together and about died when I saw the tranny and all the other parts out of the truck. Not an easy feeling.
That was two weeks ago. I have been driving the truck a lot to make sure it all works right. Everything seems fine thank goodness.
Good luck with that...
Geez
Geez
Leaky rear mains are not common on modulars-this one had just been mishandled when it was originally installed,but it took 50K miles to show that it was damaged on initial install.
JL
I will make one recommendation....
Use this rear main seal. It's the best you can get, and will ensure that you're not back in there redoing this later on after your 60 day warranty is up.
JL
Rear Main Seal Set by Felpro - Part BS40644 - Advance Auto Parts
JL
on
The 1 piece seal is clearly a better seal but at the expense of pulling the tranny. That might be easier than dropping the oil pan though. We used to drop the engine pan, rear main cap, pull the top part out and thread another one through with a wire tool that worked like one of those Chinese finger grabbers. It was only fabric with some kind of low friction coating on it. Ditto fror the bottom one. No wonder mine doesn't leak! I think a lot of extended heat would be the only enemy of the round seal.
JL
You reply clearly confused Outlaw......and if one is not familiar with these engines,or how the rear mains are made would be confused in thinking that the OEM seals are still 2 piece with a one-piece available as a replacement-they might think that pulling the pan would be an option.
JL
JL
