Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 03-24-2010, 01:38 PM
MHUNLEY's Avatar
MHUNLEY MHUNLEY is offline
Garage is empty, add now
MHUNLEY is starting off with a positive reputation.
INTAKE MANIFOLD RUNNER CONTROL
I have a 2002 f-150 with a 4.2 liter v6 engine.
my check engine light has been on for some time and occasionally at highway speeds the truck will start bucking like it is starving for fuel.
my local dealer first told me it was the fuel pump so i have a new $400.00 pump in my truck. when that did not fix my problem i took it back to my local dealer and now they are telling me that it needs to have the
imrc replaced and that as part of a tsb 07-1617 i need to replace the lower intake manifold also at $1065.00. i would like to verify this, as i really need my truck fixed. it also is having a problem starting and they explained that as the number 6 injector being stuck open and bleeding fuel into the cylinder. i am getting ready to go on vacation in this thing and need it to be running right. i do not mind spending money to fix it but i want it repaired. last time they told me what it needed it did not fix it (fuel pump)
any input is appreciated.
  #2 (permalink)
Old 03-24-2010, 02:01 PM
darkmage55's Avatar
darkmage55 darkmage55 is offline
darkmage55 is starting off with a positive reputation.
Wow sounds like a regular steelership. One of the reasons i have a mechanic i take it too thats NOT a ford dealership haha. Have you had the CEL read? What is it reading if you have?
__________________
2001 F150 4x4 5.4L 116,000 Miles, Supercab, Torsion Bar Crank, 16x10 Granite Alloy Wheels and 33x13.5 Super Swamper TSL's, Cut Off Exhaust after the cats pipes coming soon, Gotts Intake Mod, More To Come.
  #3 (permalink)
Old 03-24-2010, 06:14 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a good reputation on FTE.steve(ill) has a good reputation on FTE.
light should tell you which cylinder is the problem. normally bucking is caused by missfire. that would be coil, sparkplug, fuel injector, fuel pump, fuel pressure regulator in that order... how did they jump to the pump first?? did they measure the pressure? did it leak donw? code should say if #6 cylinder is the problem, then NORMALLY you would start with a new coil.
__________________
2002 SuperCrew 4 x 4 5.4 XLT -100K miles -NEW
2010 EDGE FWD - V6 ----------30,000 miles
2002 Explorer 4 x 4 4.0 XLT --- 162,000 miles
2001 SuperCrew 4 x 4 5.4 XLT -235K miles -GONE
  #4 (permalink)
Old 03-24-2010, 06:15 PM
steve(ill)'s Avatar
why do you need an intake manifold? got a hole, or they just need the work and money???
__________________
  #5 (permalink)
Old 03-24-2010, 08:02 PM
ottawaguy's Avatar
ottawaguy ottawaguy is offline
ottawaguy is gaining momentum as a positive member of FTE.
I would check to see if the imrc linkage rod is still connected. Wanna bet it's a p1518 code??. Any pinging(spark knock) lately?
The rods are held in by little plastic bushings and will throw a code if they break and the rod falls out. If you feel down in back of the engine behind the upper intake manifold, you should be able to feel the linking rod.
Let us know what you find.
Oh...and stay away from the dealerships and you'll save lots....
My local dealership charged my 11.73 each before taxes. Dorman makes the part(can't remember P#) in their "Help" line of repair/replacement parts...should be cheaper than the dealer.
__________________
Dave
1999 F-150 XLT Supercab 2WD 4.2
2011 Excape XLT Sangria Red SAP
  #6 (permalink)
Old 03-25-2010, 02:40 AM
Bluegrass 7 Bluegrass 7 is online now
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Sorry to hear of the fine competency the dealer has shown.
We need to know the code/s you have set, first.
There may be mutiple issues as well.
Solve for one code at a time to keep confusion to a min.
Good luck.
  #7 (permalink)
Old 03-25-2010, 10:11 AM
MHUNLEY's Avatar
THE CODES ARE AS FOLLOWS
P1519 -IRCM STUCK CLOSE
P0171 BANK ONE LEAN
P0175 BANK 2 RICH
P0306 CYL 6 MISFIRE
P0316 MISFIRE FIRST 1K
P1519 IRCM STUCK CLOSED
THEN THEY SAID MODE 6 NO MISFIRES
KOER- ALL PASS
THE SAID I NEED THE INTAKE BECAUSE OF SOME SORT OF SCREWS AND THE SERVICE BULLETIN SAYS IT WILL NEED BOTTOM OF INTAKE
THANKS FOR ALL THE INPUT
  #8 (permalink)
Old 03-25-2010, 09:53 PM
P1519 appears 2 times so 1 code down already.
Very unusual for one bank to have an "oppisite code" from the other (P0171 & P0175), one lean and one rich.
Both codes likely due to the same fault. Count as 1 fault.
P0316 and P0306 go togather so 1 fault here. 316 is detecting the #6 cylinder fault at cranking time.
You have only 3 area to address.
Fix the cylinder miss first and 316/306 will clear.
The 171/175 codes may be related to the intake/runner/manifold control issue.
A good tech will take these relationships under consideration and solve for interelated fault causes.
I think they are mostly out of your present ability to handle.
Good luck.
  #9 (permalink)
Old 03-26-2010, 08:53 AM
ottawaguy's Avatar
It's in the dealerships hands now...Usual song and dance, leaving you with a light wallet when the day's done, but as the OP stated, he doesn't mind spending money to fix the problem.
1065 for the manifold, new intake runners(?), you know they're gonna ding him for a new runner control, yada yada, all the associated parts,throw in labour .....
*#$@#!% dealerships..never been to one that didn't try to rob you blind.
MHUNLEY...Let us know how it turns out.
__________________
Dave
  #10 (permalink)
Old 03-28-2010, 05:07 PM
IndySilverAnny IndySilverAnny is offline
IndySilverAnny is starting off with a positive reputation.
Looks like a new coil wouldv'e fixed the bucking issue. My truck has done this twice now, and both times a new coil fixed it. (replaced the associated plug while it was out.
__________________
David
1991 Silver Anniversary Bronco SOLD!!!!!
2002 Ford F150 Supercrew gray 4.6L 2WD
1985 Mustang SVO The play toy!
  #11 (permalink)
Old 04-26-2010, 10:48 AM
MHUNLEY's Avatar
My truck is fixed.
6 injectors and intake reseal an irc motor and an upper intake.
the upper intake separated and needed to be replaced.
thanks for all the input, just glad it is all fixed.
  #12 (permalink)
Old 04-26-2010, 12:43 PM
ottawaguy's Avatar
Quote:
Originally Posted by MHUNLEY View Post
My truck is fixed.
Glad you got it solved!
Thanks for posting the fix....
__________________
Dave
  #13 (permalink)
Old 11-14-2010, 03:45 PM
anderson1549 anderson1549 is offline
anderson1549 is starting off with a positive reputation.
My 97 F150 was not getting much power at take off. Felt like it was trying to started but needed a walking cane to help it get up. Once it started moving and the rpm got up I could feel the IMRC valves open up. So I unhooked the control modules from the runner and opened the valves and I have power through out the rpm range. There may be something else wrong but it is running good now.
Tags
1997, 2001, 42, 54l, bushing, control, f150, ford, imrc, intake, location, maifold, manifold, plastic, runner, test, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
