Minnesota Chapter Join Chapter, Leader: fordpower88
View Poll Results: GTG Dates
April 10-11
71.43%
April 17-18
0%
April 24-25
28.57%
May 1-2
0%
Voters: 7. You may not vote on this poll
GTG
Old 04-06-2010, 09:07 PM
DieselCamper01's Avatar
DieselCamper01
DieselCamper01 is online now
Originally Posted by lowboy250
Will anyone be there with a diagnostic tool at all? I need to figure out if my truck needs injectors. Also what to get and why.
If Tom makes it he has AE
Old 04-06-2010, 09:10 PM
Skattracker3's Avatar
Skattracker3
Skattracker3 is offline
I hope to make it. I know my programmer will read codes, but not sure about injectors unless it throws a code.
Old 04-07-2010, 09:44 PM
Ford79's Avatar
Ford79
Ford79 is offline
What projects are on everyone's list?
I still haven't got my compressor moved to the shop, don't know if I will before Saturday or not. If you need air for a project, we can work out of the attached garage too or I may just bite the bullet and wire the compressor in the shop, depends on cost of wire now.
If you need directions, PM me and I'll send them to you
Old 04-07-2010, 10:28 PM
lowboy250's Avatar
lowboy250
lowboy250 is offline
I'm pretty sure that I need directions.... So, it's straight, then a curve to the right then I'm there, right? Pretty sure that I can make it there on the starter and the battery if I have to....
Old 04-08-2010, 04:57 AM
mndiesel's Avatar
mndiesel
mndiesel is offline
I will be there with my AE, can scan all day if i need to.
Old 04-08-2010, 05:03 AM
mndiesel's Avatar
mndiesel
mndiesel is offline
Things I need to do would be to:
Get the rear axle fill cap out
Check the driveline for bad u-joints and carrier bearing
Find out why my windshield washer doesn't work and delay on wipers doesn't work
Other things to do if time:
Flush power steering, trans and coolant (probably wait on these)
Old 04-08-2010, 07:29 AM
Skattracker3
Well Mike, I need to do front brakes and rotors, but I will do those at home in case I have issues, so I will be their just for moral support or a strong back and weak mind, whatever you prefer.
What time are you thinking about, and is it Sat the 10th for sure?
Old 04-08-2010, 08:45 AM
Ford79's Avatar
Ford79
Ford79 is offline
Don't forget the right out of the driveway and the left onto 88th
That will make 2 of us then
Any time after 9 should be fine. Yes, Sat. the 10th it is.
Old 04-08-2010, 10:17 AM
lowboy250's Avatar
lowboy250
I won't be able to spend too much time there, I have a couple things that came up. But I would like to meet everyone and check my 95 'stroke out for the injectors like I mentioned. Will AE work on my truck?
Old 04-08-2010, 10:54 AM
Ford79's Avatar
Ford79
Ford79 is offline
I'm not sure AE will work. What's the port under the steering wheel look like?
Old 04-08-2010, 10:57 AM
lowboy250's Avatar
lowboy250
It's not under the steering wheel, it's under the center of the dash. It's an OBDII style connector.
Old 04-08-2010, 11:10 AM
Ford79's Avatar
Ford79
Ford79 is offline
Sorry, that's where I meant. If it is OBDII, AE should work. We'll find out Saturday
  #28
Old 04-08-2010, 11:12 AM
lowboy250's Avatar
lowboy250
Great! I need to get to the bottom of this running quality issue. How long will you guys be there? It would be better for me to stop by at 5:00 or so.
  #29
Old 04-08-2010, 04:03 PM
fordpower88's Avatar
fordpower88
fordpower88 is online now
I will be there on Saturday! Looking forward to meeting some new people. Don't really have to much to do on my truck for now. I should take my EBPS tube off and clean that to see if that clears up the code Tom found when he scanned my truck. Mike is there anything we need to bring?
  #30
Old 04-08-2010, 08:38 PM
Ford79's Avatar
Ford79
Ford79 is offline
That's great that you'll be able to make it Troy.
I don't think so, I should have most tools that will be needed.
Does anyone have a preference for lunch? Burgers? I'll stop tomorrow while I am out running and pick up some pop(what's everyone drink?) and chips. Beer? Any other food related items? Any other non food related items?
Quick Reply: GTG
