Replacing Instrument Panel Lights &
https://www.ford-trucks.com/forums/5...ng+dash+lights
here ya go for the pannel lights. its really pretty straight forward. dont just replace the big bulbs do the little ones two.... i made that mistake.. .
at least the three in the top of the speedometer.
if you find the answer for the mirror, i too am interested in the answer.
Another pointer, when you replace the instrument cluster lights, go with LEDs. You will never have to change them again. And yes, do them all. Otherwise you can have another one go out at any time. While not the hardest job out there, it is not something you want to do again.
You just start by removing the panels in going for it. You might need a set of start drives, some of the bolts might have a torx head.
Thanks for the info.....I don't know how to get the dash apart.....the 3 screws up under the speedo area are easy but what comes next or first? Tried prying a bit on the piece near drivers door....no luck. Any way to take the top of the dash over the speedo out? Or is it accessed by some other way?
Thanks, Goudey
Thanks, Goudey
Copy and paste this link
Picasa Web Albums - gregg - Gauge Lights ...
I used it when I did mine and it is step by step with pictures. Saved a lot of headaches. Hope this helps you out
Justin73supercamper
06-03-2016 07:54 AM
bf5113x
01-15-2016 04:58 PM
ydaveitsu
12-23-2015 05:43 AM
