Replacing Instrument Panel Lights & - Ford Truck Enthusiasts Forums
Old 03-23-2010, 08:02 PM
Goudey Goudey is offline
Goudey is starting off with a positive reputation.
My 97 F 150 left side of the inst panel is dark. How to change the bulbs?
Also the glass in the left hand mirror shakes....How to tighten it up if possible?
Thanks for any info.
Richard
Old 03-23-2010, 09:20 PM
fordf150farmer's Avatar
fordf150farmer fordf150farmer is offline
fordf150farmer is starting off with a positive reputation.
http://www.ford-trucks.com/forums/52...ng+dash+lights
here ya go for the pannel lights. its really pretty straight forward. dont just replace the big bulbs do the little ones two.... i made that mistake.. .
at least the three in the top of the speedometer.
if you find the answer for the mirror, i too am interested in the answer.
Old 03-24-2010, 10:47 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
Another pointer, when you replace the instrument cluster lights, go with LEDs. You will never have to change them again. And yes, do them all. Otherwise you can have another one go out at any time. While not the hardest job out there, it is not something you want to do again.
You just start by removing the panels in going for it. You might need a set of start drives, some of the bolts might have a torx head.
Old 03-24-2010, 02:25 PM
Thanks for the info.....I don't know how to get the dash apart.....the 3 screws up under the speedo area are easy but what comes next or first? Tried prying a bit on the piece near drivers door....no luck. Any way to take the top of the dash over the speedo out? Or is it accessed by some other way?
Thanks, Goudey
Old 03-24-2010, 08:58 PM
Marty's 97 F-150 Marty's 97 F-150 is offline
Marty's 97 F-150 is starting off with a positive reputation.
Copy and paste this link
Picasa Web Albums - gregg - Gauge Lights ...
I used it when I did mine and it is step by step with pictures. Saved a lot of headaches. Hope this helps you out
Old 03-24-2010, 10:24 PM
Podaso Podaso is offline
Podaso is starting off with a positive reputation.
If you find answers to the mirror vibration, I need to know too...I think it's because the panel/cover (matching your paint color) on the back lets air in, but I'm not sure. I do know the panel is removable.
Old 03-24-2010, 11:20 PM
firefighter1416's Avatar
firefighter1416 firefighter1416 is offline
firefighter1416 is starting off with a positive reputation.
had the mirror vibration issue as well guys only solution i found was a whole new mirror, i tried everything to fix it.
Old 03-25-2010, 12:38 AM
Do you remember how much that cost? My mirrors have the "invisible" signals in them so they're probably more than normal.
Old 03-25-2010, 08:24 PM
i just kept my eyes on ebay and found a pair of used ones from a junker, i think i gave 80 for a pair of electrics with a painted cover
Switches ligito 1999 to 2016 Super Duty 15 08-07-2016 11:06 PM
Pics of my Trim panels below door panels Justin73supercamper 1973 - 1979 F-100 & Larger F-Series Trucks 7 06-03-2016 08:54 AM
left side dash panel mark_k 1999 to 2016 Super Duty 0 02-19-2016 02:31 AM
Panel Removal help request jonrjen 6.7L Power Stroke Diesel 5 07-12-2015 08:43 AM
Remove side panel to left of dash? Budlight592 6.7L Power Stroke Diesel 5 02-28-2012 10:41 AM
Tags
1997, 2003, 97, bulb, bulbs, cluster, dash, f150, ford, instrument, lights, panel, replace, replacing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
