Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-23-2010, 06:42 PM
fixnair's Avatar
fixnair fixnair is offline
Garage is empty, add now
fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.
fixnair
Flathead V8 fuel pump
Anybody know where can get a repair kit for a 239 V8? I hate to pay for a complete pump
__________________
2002 F350 7.3 Ltr. 6sp.DRW 270K miles, 13' service body
1952 F1 flathead Project Truck
2008 Lincoln MKX
need thermostat housing & cab 4 project
  #2 (permalink)
Old 03-27-2010, 01:49 PM
Red97350 Red97350 is offline
Red97350 is gaining momentum as a positive member of FTE.
You can try Macs antique auto parts.
MAC’s: Dealer of Restoration Parts for Classic, Antique, Vintage Ford Autos, Cars & Trucks: Street Rod Parts, Vintage/Classic Ford Manuals & much more!
Red
__________________
1997 F-350 Reg cab 4x4 7.3 PSD 176k
2002 Excursion PSD 220k
  #3 (permalink)
Old 04-15-2010, 08:33 AM
55 f350's Avatar
55 f350 55 f350 is offline
1953 Ford F-100
55 f350 has a great reputation on FTE.55 f350 has a great reputation on FTE.55 f350 has a great reputation on FTE.55 f350 has a great reputation on FTE.55 f350 has a great reputation on FTE.
macs , dennis carpenter had 'em , and try job lots . this is my personal experience / opinion though { the following that is } : if your's is gone put an electric on it , and get a fuel pump stand block off plate . the electric won't vapor lock or give you any issues at all . seems to be a pretty common thing to do with them . i put mine back together with the oe pump when i first got it and didn't know the little trick of filling the pump stand { with pump attached } with grease or vasoline to hold the pushrod in place ..... well long story short it chucked the rod , bent it , and meesed up the pump arm end so ........................ now i got an electric !!!!!!!!!!!!!!!!!!!!
__________________
that's because were all opinionated bullcrap artists looking for somewhere to espout our views and show the world how much we { don't } know especially to newcomers. were on a mission to impress you and make you believe we are all knowing ! P.A.D.D = project attention deficit disorder . everyone on here has it , and is an enabler !!!! so enter at your own risk !!!!!!!!!!! if you don't have 2 or 3 broken fords / projects , then you just ain't right !!!!!!!!!!!!!!!!
  #4 (permalink)
Old 11-22-2010, 09:48 PM
3Dchris 3Dchris is offline
3Dchris is starting off with a positive reputation.
hello, i have a 51 F-1 and put a new fuel pump on it making sure the puch rod stayed in the cup on the pump but it doesnt want to pump any fuel. I pulled the hose from the pump to carb and used a gravity fed can to start and run the motor and it still wont pump any fuel---- any suggestions. It's a 239 V-8.
thanks
  #5 (permalink)
Old 11-27-2010, 02:10 PM
merlynr's Avatar
merlynr merlynr is offline
merlynr is gaining momentum as a positive member of FTE.
Didn't they shim the rod back in the day?
__________________
97 F250 4X4 7.5
71 F350 dump 360
99 Explr XLS 4.0
07 Edge SEL+ fwd
  #6 (permalink)
Old 12-19-2010, 07:30 AM
Dan Robertson Dan Robertson is offline
Dan Robertson is starting off with a positive reputation.
Your fuel pump runs from a push rod that rides on a lobe on the camshaft. The cam often wears as does the push rod. I have a 46 Ford that developed fuel pump problems. I tried a trick that an old timer told me about. I put a small piece of leather in the push rod cup on the pump. It lengthens the push rod and the leather doesn't seem to hurt anything. I used a common paper punch to punch a hole in a regular leather belt. The "punch out" is just the right size. My truck is original, including the 6 volt system and I do not want to alter it. I also didnt want to order a 6 volt pump. I only run the truck around my farm during the summer. Its not a perminant fix but the leather trick worked for me. Good luck.
Tags
1948, 1952, 239, 53, engine, f1, flarhead, flathead, ford, fuel, kit, pump, stand, starvation, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
