Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Transmission Guides
- What Causes Transmission Leaks?
Guide to diagnose trouble and recommended solutions
Oil/Transmission Fluid in my Coolant Reservoir!!!!!!!!!!!
So I just got back from doing an oil change at Jiffy Lube and the tech called me over and showed me my reservoir and it was BLACK. They took a little out and showed me and the coolant is somehow mixed with some type of oil but they are not sure if it's tranny fluid or engine oil. I am very concerned and even though I'm not overheating I do not want to damage my motor. What could be causing this?
Good call my man, the radiator works as a tranny cooler too so maybe the radiator is going bad, mixing the tranny fluid with the coolant? Hmm I changed my solenoid and tranny fluid a few months ago so I'll check the level and see.
Tomorrow Im going to drain the coolant from the radiator to see what it looks like. What steps should I take if
a.) The coolant comes out black (mixed with oil just like it looks in the reservoir)
b.) If the coolant is mixed with transmission fluid (reddish mixture)
Btw, I dont know if Im just paranoid but I noticed now that the tranny might be slipping a little but guess this, ONY WHEN I MAKE U-TURNS! Very strange...sigh
I had an 88 firebird with a 5.0 it got oil in overflow. My bro was still alive and had a shop he did a test on my rad and found out I was getting exhaust gases flowing in to the rad. You know lazy back then since no water was in the oil I never did replace the head gasket or check to see if it had a cracked head,but we did run it for more then 100,000 more miles.Still ran when it was parked 5 years ago.Hope yours is an easy repair
If the coolant got into the trans you could be in for some expensive problems. When you check the trans fluid if it looks a bit like a milkshake in there, the coolant got to the trans and the only way to attempt a cure is to immediatly change the fluid after you change the radiator. Do not operate the truck for any reason until the radiator and TRANS FLUID is replaced. You should also get a good transmission cooler and bypass the radiator cooler. A new radiator is much less expensive than a transmission if it should fail again.
