leaking air conditioner on expedition
You should be able to find the drain tube from underneath the passenger side between the firewall and cab area. A black piece of tubing approx. 3/8" diameter. Can back flush with peroxide as mentioned above or a 10% bleach solution which will disinfect any mold. (1 part bleach to 9 parts water). You drain tube may also be loose, so use caution if using bleach that you don't wind up with it on your carpet. Put down protective covering regardless of which agent you use. Purchase a new turkey baster and give it to your wife along with a big kiss, use the old one as a flush tool. Marital crisis averted.
