Hi all. Have a question regarding the front passenger dor handle. I would like to switch it with one without the keyhole. Can I just order the rear right outside door handle for the front passenger side. Are the clips that hold it into place the same? Will it fit without any modifications? Also do you think its best to order the dealer part or after market is same quality?
No I don't. You will have to remove the interior door panel and then two nuts hold the latch to the door. Actually, I think one of the two is accessed thru a rubber plug, outside the door panel.
