Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-23-2010, 07:58 AM
FarmerFrank's Avatar
FarmerFrank FarmerFrank is offline
Garage is empty, add now
FarmerFrank is starting off with a positive reputation.
93 tach?
Howdy, im attempting to wire a tach into my 93 ranger. its the 8 plug 2.3 with all the coil pack things on it. now the tach has 4 wires, red, black, green and white. i know the white one is for the light in it, blacks my ground, but not sure what that green one does or where to hook up my red. each set of packs has 3 wires going to them and i tried hooking it in to all 6 wires, at seperate times, and it works while im at idle but as soon as i give it gas the tach just drops. take my foot off the gas and it will jump to the rpm i was at and fall with it and it seems accurate, but why does it do this?
  #2 (permalink)
Old 04-07-2010, 08:43 PM
whitefordexplorer's Avatar
whitefordexplorer whitefordexplorer is offline
1991 Ford Explorer
My Garage
whitefordexplorer is gaining momentum as a positive member of FTE.whitefordexplorer is gaining momentum as a positive member of FTE.
cooksmobile@yahoo.com MUSCLEDRIFTER
hrmmmmm... i would consult the manufacturer of the tach. see if they have a diagram or something to follow. let me know what you come up with, i plan on doing the same for my '92. with the same motor.
__________________
-Landon
My wife said if i didnt stop spending money on my truck and not her, she would leave..... My new girlfriend loves my truck!
if it has t**ies, tires or tools, it has my full attention.
  #3 (permalink)
Old 04-07-2010, 10:07 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
1969 Ford F-250
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
Red is switched power for the tach, and green is signal pickup. You should consult the manufacturer about hooking it up, since it sounds like you don't have any instructions with it. Many tachs need an adapter to run on a distributorless engine.
__________________
Jared
Real trucks have the key on the left
FTE Guidelines
  #4 (permalink)
Old 10-19-2010, 08:01 PM
jfive's Avatar
jfive jfive is offline
1979 Ford F-150
jfive is starting off with a positive reputation.
The DIS module on the intake manifold has like 6 wires coming out of the bottom of the module and the far right wire, which is black with yellow strip or yellow with brown is the signal wire for the tack. You need to splice the green wire from the tach to this wire, and then hook up the red to a postive when key is on, and black to a ground, and then the white is for the light which goes off the headlights.
Tags
1992, 23, 92, 93, explorer, ford, hood, hook, inline, ranger, tach, tachometer, truck, view, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
