3.55 vs 3.73
3.55 vs 3.73
I'm looking at replacing my 07 with a 2010. It might be a F150 but I may end up going the Super Duty route. Just not sure yet. But in my online search, I've noticed most Lariats have 3.55's unless they have the max tow package. And the FX4's have the 3.73's.
I'm wondering if the 3.55's are enough with the 5.4 and 6 speed or if I should be searching a FX4 or Lariat with Max Tow?
I can't imagine how doggy my 07 would have been if it only had 3.55's because with 3.73's, it's still lacking a bit.
What would you guys look for?
if 4.10's are an option i would definitely do that. people might say thats too low and it will hurt your mileage. not so true if you do alot of stop and go, in town traffic. the extra grunt off the line will show it's difference at the pumps, and may outweigh the price jump to a superduty
on
When I was at the lot looking for mine 4.10s were still an option then and that was 2 weeks ago. I just didn't want that because the odds of this seeing any towing at all is slim to none especially considering I don't own any bumper pulls so it would have to be a rental trailer either from Co-Op or Home Depot(which I doubt).
4.10 is only an option on the Raptor. The first gear in the new 6 speed is super low geared so you don't have to go with a low rear ratio. I have 3.73 and it is plenty low. I'd advise you to drive each and see which gear set will work for you. If you truly plan on towing a lot, 3.73 max tow package is more likely the route for you. You get more than just the 3.73 ratio with max tow as well.
Most definately not! The Tow/haul mode doesn't lock out your top gears. It gives the motor some extra RPM's before shifting, allowing the trans to hold the gear without bogging from low RPMs. Also, tow/haul downshifts a gear each time you tap the brakes for engine braking (works awesome). I have heared that under normal driving, 1st gear is not used because it is so low. I don't know if this is true (my trans shifts too smooth and quickly for me to notice, even with a tach) but first is definately used in tow haul. Really a pretty cool feature.
steverinaz
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
03-03-2017 08:22 AM
