Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > New England Region > Connecticut Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Connecticut Chapter Join Chapter, Leader: StreamlineGT
  #1 (permalink)
Old 03-22-2010, 10:32 PM
Mikproc Mikproc is offline
Garage is empty, add now
Mikproc is starting off with a positive reputation.
6.0 emission test
Hey guys I just got my reminder in the mail the other day and its time to get my emissions tested! I cant wait. I have a worry or 2 as you would imagine and was wondering if anyone knew of a place that would test a truck even if it happened to be missing an emissions device or 2? Shoot me a pm if you could or email me. Thanks a lot guys I appreciate the help. Also has anyone had the test done yet on a 6.0 f350?
Mike
  #2 (permalink)
Old 03-22-2010, 11:03 PM
7.3 Rocket's Avatar
7.3 Rocket 7.3 Rocket is offline
Non-smoker
7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future
You could register it for 10,001lbs and then I do believe it is emissions exempt. I know our 6.0 dually is exempt from emissions testing cause it's over 10,000.
__________________
-Pete, PAA member #84
  #3 (permalink)
Old 03-23-2010, 05:12 AM
Zookie400's Avatar
Zookie400 Zookie400 is online now
Zookie400 is a splendid one to beholdZookie400 is a splendid one to beholdZookie400 is a splendid one to beholdZookie400 is a splendid one to beholdZookie400 is a splendid one to beholdZookie400 is a splendid one to beholdZookie400 is a splendid one to behold
pete is right, the only downfall is the registration is only for one year instead of 2.
your 6.0 should be an obdII check, so as long as you have no check engine light you should pass.
__________________
Since light travels faster than sound, some people appear bright until
you hear them speak.
MY YOUTUBE VIDEOS
  #4 (permalink)
Old 03-23-2010, 03:15 PM
Thanks for the info guys I will look into registering at 10,001 lbs!
  #5 (permalink)
Old 03-23-2010, 04:37 PM
Aerocell4x4's Avatar
Aerocell4x4 Aerocell4x4 is offline
Diesel Van Enthusiast
2006 Ford E-Series Van
Aerocell4x4 has a great reputation on FTE.Aerocell4x4 has a great reputation on FTE.Aerocell4x4 has a great reputation on FTE.Aerocell4x4 has a great reputation on FTE.Aerocell4x4 has a great reputation on FTE.
Hi there Mike:
Is your F350 a dually, I don't see a Garage or Album for you to see for myself?
I ask because I'm not sure one can register a vehicle for a GVW greater than its sticker says and if you are SRW then you'd be under 10,000 pounds.
Quote:
Originally Posted by Aerocell4x4 View Post
And now I know why the emission testing place didn't connect into my ODBII port.
CT Emissions Program - What Should I Know About the Test - Tests for Diesel-Powered Vehicles
"Diesel vehicles that are model year 1997 and newer AND under 8,501 lbs. will receive an on-board computer diagnostic test.
Diesel vehicles under 8,501 lbs. and 1996 and older will receive a dynamometer test if they operate in two-wheel drive and are non-traction controlled. A modified test will be used if the vehicle is four-wheel drive and has non-disengageable traction control.
These diesel tests use an opacity meter to measure the density of smoke from a vehicle's tailpipe. The darker the smoke, the more it is polluting and the higher its opacity reading will be."
The place I went to only stuck a sniffer pipe into my exhaust pipe.
He thought that I was to be dyno'd but since I couldn't fit into the corner of the garage where he had the machine, he just annotated my emissions report with 'would not fit on machine.'
__________________
Dave ~*~ Mods are listed in my Gallery (Updated 03/11/2010)
Former Connecticut Chapter Leader Feb. 06, 2009 to Aug. 22, 2010.
2006 E35Q 6.0 5R110 35.4" Tires & 5.13 Diff., Unicell's Aerocell SRW body with Quigley 4x4 Conversion - - - 2004 Expedition XLT 5.4L 4X4 4R75W 3.73 Posi
Prior: Courier Pickup and a 1991 Crown Victoria Interceptor
  #6 (permalink)
Old 03-23-2010, 05:51 PM
Hey Dave, my truck is a srw. So I guess I wont be able to register for that then I believe my trucks rated at 9900. From that quote you posted it looks like all I need to do is pass the visual and a smoke test. No OBDII luckily! Thank you for the info I will just call around and see who does diesels and let you guys know what happens.
Tags
2003, 60, check, diesel, emission, emissions, f350, ford, good, light, opacity, reading, test, testing, vehicle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
