A/C Compressor (maybe clutch) Making Noise
Old 01-24-2003, 09:58 PM
cvlngineer's Avatar
cvlngineer
cvlngineer is offline
Hello,
I have a 1996 F-150 with an inline 6 cylinder engine. Either the A/C compressor clutch or the compressor itself is making a rattling/clinking noise every 15-25 seconds or so. I don't know if it is the bearings, the clutch or the compressor itself. Is there a way to determine which it is? I am trying to figure out which part to buy.
Another question: The engine temperature always stays just at the lower edge of the normal operating range. Does this mean that the thermostat is going out?
cvlngineer
Old 01-24-2003, 10:34 PM
steve83's Avatar
steve83
steve83 is offline
Use a screwdriver (before you start the engine) to hold the fan still so you can hear the engine noises better, then use a piece of garden hose as a stethoscope to isolate the sound.
The gauge is NOT reliable.
Old 01-24-2003, 10:58 PM
cvlngineer's Avatar
cvlngineer
Steve,
Thanks for the reply. There is no need to muffle any surrounding noise. The noise from the clutch/compressor is quite loud. I can also see the clutch jumping a bit when it makes the noise. The noise sounds sort of like the clutch is slipping excessively. It is not really a grinding noise, but a clangey scrrriiiippp-scrrriiiipppp sound. It appears that the compressor is cycling on or something, and maybe the clutch is having trouble engaging. It does it for a few seconds and then stops. And about 15-25 seconds later, it does it again. It does it regardless if the A/C is running or not. I even unplugged the electrical connector from the compressor and it still did it. The A/C does work, however.
cvlngineer
Old 01-25-2003, 02:01 PM
steve83's Avatar
steve83
steve83 is offline
Sounds like the clutch is fragged or it needs to be shimmed. There is a single nut in the middle of the clutch that holds it onto the keyed shaft. Behind that are some paper-thin shim washers that are used to adjust the gap between the clutch & the pulley face. You can probably find the specs here, but you can certainly find the diagrams.
Old 01-25-2003, 08:12 PM
cvlngineer's Avatar
cvlngineer
Thanks for the help!
I replaced the A/C clutch and it did the trick. The bearings and most of the other innards of the old clutch were shot.
I also replaced the thermostat and housing. I now have a normal operating temperature, but I still have no heat in the cab, I think it actually got worse! Any ideas on what to do about that?
Thanks,
cvlngineer
Old 02-04-2003, 12:32 PM
wtf's Avatar
wtf
wtf is offline
Any trick to replacing the clutch and seal?
I took my clutch off and the seal below it was gone! It burn't up somehow, perhaps related to a new serpentine belt the dealer told me was after market and too long. Anyway, I need to remove the lock ring and replace the seal. The clutch is red which I have been told is a sign it is bad. The new clutch is $63 and I just can't see how this can go bad. I do get some noise when I spin the pulley without the clutch on it. It looks like there should be more bearings in there but I haven't found anyplace/anyone to confirm what it should look like.
tia,
Profanity Removed
tractorboy924
07-13-2017 11:26 AM
1956lando
01-12-2013 11:45 AM
WINGNUT-
08-29-2011 08:14 PM
ebraunusa
1997-2006 Expedition & Navigator
05-25-2007 12:37 PM
Quick Reply: A/C Compressor (maybe clutch) Making Noise
