A/C Compressor (maybe clutch) Making Noise - Ford Truck Enthusiasts Forums
Old 01-24-2003, 10:58 PM
cvlngineer cvlngineer is offline
cvlngineer is starting off with a positive reputation.
Hello,
I have a 1996 F-150 with an inline 6 cylinder engine. Either the A/C compressor clutch or the compressor itself is making a rattling/clinking noise every 15-25 seconds or so. I don't know if it is the bearings, the clutch or the compressor itself. Is there a way to determine which it is? I am trying to figure out which part to buy.
Another question: The engine temperature always stays just at the lower edge of the normal operating range. Does this mean that the thermostat is going out?
cvlngineer
Old 01-24-2003, 11:34 PM
steve83's Avatar
steve83 steve83 is offline
steve83 is starting off with a positive reputation.
Use a screwdriver (before you start the engine) to hold the fan still so you can hear the engine noises better, then use a piece of garden hose as a stethoscope to isolate the sound.
The gauge is NOT reliable.
Old 01-24-2003, 11:58 PM
Steve,
Thanks for the reply. There is no need to muffle any surrounding noise. The noise from the clutch/compressor is quite loud. I can also see the clutch jumping a bit when it makes the noise. The noise sounds sort of like the clutch is slipping excessively. It is not really a grinding noise, but a clangey scrrriiiippp-scrrriiiipppp sound. It appears that the compressor is cycling on or something, and maybe the clutch is having trouble engaging. It does it for a few seconds and then stops. And about 15-25 seconds later, it does it again. It does it regardless if the A/C is running or not. I even unplugged the electrical connector from the compressor and it still did it. The A/C does work, however.
cvlngineer
Old 01-25-2003, 03:01 PM
steve83's Avatar
Sounds like the clutch is fragged or it needs to be shimmed. There is a single nut in the middle of the clutch that holds it onto the keyed shaft. Behind that are some paper-thin shim washers that are used to adjust the gap between the clutch & the pulley face. You can probably find the specs here, but you can certainly find the diagrams.
Old 01-25-2003, 09:12 PM
Thanks for the help!
I replaced the A/C clutch and it did the trick. The bearings and most of the other innards of the old clutch were shot.
I also replaced the thermostat and housing. I now have a normal operating temperature, but I still have no heat in the cab, I think it actually got worse! Any ideas on what to do about that?
Thanks,
cvlngineer
Old 02-04-2003, 01:32 PM
wtf wtf is offline
wtf is starting off with a positive reputation.
Any trick to replacing the clutch and seal?
I took my clutch off and the seal below it was gone! It burn't up somehow, perhaps related to a new serpentine belt the dealer told me was after market and too long. Anyway, I need to remove the lock ring and replace the seal. The clutch is red which I have been told is a sign it is bad. The new clutch is $63 and I just can't see how this can go bad. I do get some noise when I spin the pulley without the clutch on it. It looks like there should be more bearings in there but I haven't found anyplace/anyone to confirm what it should look like.
tia,
Profanity Removed
ac not blowing cold compressor making strange noise chrislambing 1999 to 2016 Super Duty 7 03-14-2015 04:53 PM
2002 Explorer Pulley Noise 1956lando Explorer, Sport Trac, Mountaineer & Aviator 3 01-12-2013 12:45 PM
A/C Compressor Clutch texaskid22 1987 - 1996 F150 & Larger F-Series Trucks 1 02-21-2011 11:36 AM
Voltage at A/C compressor - no clutch engagement? tobyw 1987 - 1996 F150 & Larger F-Series Trucks 10 05-30-2007 01:56 PM
changing a/c clutch 2020 Cooling, Heating, Ventilation & A/C 2 06-04-2006 07:20 AM
Tags
1996, ac, bearing, bronco, changing, clinking, clutch, compressor, f150, ford, grinding, making, navigator, noise, nosie, taurus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
