2004 powerstroke 6.0
I have a 2004 powerstroke 6.0 that is starting to give me problems. I have 146000 miles on it. The problem is that when I start the engine and drive for awhile it will sometimes excellerate on its own like it just got a shot a fuel and when I stop the <NOBR id=itxt_nobr_1_0 style="FONT-WEIGHT: normal; FONT-SIZE: 100%; COLOR: darkgreen; FONT-FAMILY: verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif">truck</NOBR> it will sometimes idle down and start missing and shaking the entire truck. I can turn it off and restart it and the problem goes away for awhile and then will come back. It sometimes revs up the engine when you are stopped at a stop light. Here's the kicker, it doesn't do it in cold weather. As long as the weather is below around 50F, it has no problems. When the weather warms up the engine starts its rough idleing and engine rev ups. There is no change in the exhaust color and there or no mods to the engine. One website says it may be ICP or IPR sensor. Not sure what this does. Can anyone shed any light on this issue? <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
<!-- controls -->
Definetly a later 04'. ICP is located on the valve cover. I'm not getting any codes on the sensor. Should I go ahead and replace it or maybe the wiring plug to it? The only code I get is on the cam sensor. (P0341) The problem is it doesn't do it all the time so I'm having a problem diagnosing it. Sometime surge, sometimes it don't. Sometimes it idles really rough, sometimes really smooth.
My 04 does the same thing. I was told to change the ebp sensor, so I did and the problem was gone for about 2500mi. It has come back once but thats it. I had no codes Just took a 400+ mi trip and ran like a champ. Before the trip I had to get new batteries, the reason I bring this up is I have read in other treads that the ficm is very voltage sensitive. I sware it runs like a different truck since the batteries.
If I remeber it was around $95 at the dealer. I don't belive that was my problem, but may have been a factor. You got me thinking on the air temp thing, I think mine was getting worse as the out side temp whent up. I towed my 11,000 pound rv this past weekend and it was 73 here in Michigan and the truck ran perfect I still think it has to do with the new batteries. By the way went with the Yellow top optimas.
