Rearend Vibration...
ok,
so i just hit 53,000 miles a couple days ago and yesterday on my way to church i noticed a slight shudder/vibration coming from the rear-end while pulling away from a stop and turning.
now, i'm pretty sure it's the clutch packs but is this normal for just over 50,000 miles. I do some towning and when i do it's either firewood or a 4wheeler so not to heavy and i'm not hard on it by any means.
will the dealer fix this or are they going to try to screw me witht he bill?
thanks,
thanks,
You can DIY but if you dont know anything about aligning the gears back up and backlash etc i would just bring it in. and as far as after market i dont think they make anything that will fit into stock? i might be wrong. If you were to DIY and not knwo what your doing it could turn from $500-600 into $2500 after replacing everything
well, i got the truck back today. They said their isn't a TSB for it and said that all i needed was some more friction modifier. i'm a little hesitant about it. I have 53,000 miles on it and they are trying to make me pay the bill also for the 1/2 hr labor and friction modifier they put in today.
what do you guys think?
My bad, even if there is no TSB it should be under warranty if you have warranty because even with out the TSB they said it was still covered adding more friction modifier wont solve it if the clutches are already shot
they said they opened up the rear and the oil wasn't dirty. The chatter i was getting was only in the morning when it was cold so to speak so i thought maybe it's just a sticking clutch pack. I'm not hard on the truck at all so i thought maybe the friction mod might fix it. i just started noticing it so it's noly been happening for a couple days now and only a couple times i drive. Once i'm moving a coupel minutes it stops for the most part.
