Rear Cam Plug - Ford Truck Enthusiasts Forums
Rear Cam Plug
Old 03-22-2010, 01:07 PM
Hayesn Hayesn is offline
Hayesn is starting off with a positive reputation.
Question Rear Cam Plug
I have a 65 F-250 With the 352 V8 and Std Tranny. I need the Plug that goes on tyhe back of the Camshaft. (In the block behind the flywheel). Can anyone tell me where I can get this part. The old one popped out and is stamped 2 3/8. I assume this to be the size. Is it correct. Any help is appreciated.
Thanks NH
Old 03-22-2010, 01:52 PM
bertha66's Avatar
bertha66 bertha66 is offline
bertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud of
Your local parts supply should have that part.
Old 03-27-2010, 11:59 PM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
If the plug popped out you should check the camshaft end play as they don't pop out for no reason . Be certain the plug you get is correct for the cam as there are core plus of the same diameter. For all the work involved I'm sure you won't want to do it a second time because of using the incorrect plug. You might also try some marine engine shops in your area.
Old 03-30-2010, 12:48 AM
Cam Plug.
I will have it checked, However at this point I am getting desperate to find a plug. I have tried all of the local parts suppliers and have done numerous searches and havn't come up with anything. NH
Old 03-30-2010, 02:14 AM
Moto Mel's Avatar
Quote:
Any automotive machine shop should have them in stock. Try "Rock Auto"
Old 03-31-2010, 12:22 AM
Thanks for the help. I found one at Rockauto. Dorman P/N 555054
NH
Old 03-31-2010, 11:48 AM
Moto Mel's Avatar
NH
Thats good, glad to be of help.
Be careful on the installation of the new plug as there is a correct way to install it. If the installation is done by just hammering it in you can be sure you will do the job again as it will leak or come out again.
Old 03-31-2010, 08:26 PM
MeanGene427 MeanGene427 is offline
MeanGene427 is gaining momentum as a positive member of FTE.
You might want to check that they gave you the correct plug, it's not a normal "freeze" or water jacket plug, make sure they know it's the rear cam plug- and it also installs the opposite way from a freeze plug, cup to the inside, not the outside- if it looks backwards compared to the water jacket plugs, it's in correctly. Chances are the last one was installed backwards, and that's why it came out
replacing my glow plugs JoshC017 6.0L Power Stroke Diesel 11 10-16-2016 09:38 AM
1969 f600 rear differential fluid level imjstsitner Large Truck 3 12-07-2015 02:10 AM
stripped oil rail plug! Jerry Chaney 1999 - 2003 7.3L Power Stroke Diesel 7 01-11-2014 09:10 PM
glow plugs zd10 jps47 1999 - 2003 7.3L Power Stroke Diesel 2 11-16-2013 03:50 PM
Best spark plug for 08 6.8L V-10 WestxSRT10 1999 to 2016 Super Duty 7 09-13-2012 11:29 PM
Tags
460, 50, cam, camshaft, diameter, fe, ford, freeze, jacket, location, plug, plugs, popped, rear, truck, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
