When was the cut off for early/late 99? - Ford Truck Enthusiasts Forums
Old 03-22-2010, 12:56 PM
jt371's Avatar
jt371 jt371 is offline
jt371 is gaining momentum as a positive member of FTE.
I have a 99 F-250 built 2/99. Which I have been told is a late 99. It has all the late 99 engine parts. I needed to replace the front sway bar bushings. A guy I work with had given me the ones he had taken off his truck when it was new and he installed a lift kit. His was an 02. So one day I had I went to swap them out and found them to be longer links and with larger bushings. So orderd a bushing kit. Went to install and found the same problem. Kit said it covered 99. Did some research and found that there was another kit for the 99's, ordered and it was the correct kit. Installed and now finally that clunk is gone. Just curious if my sway bar was a leftover. I know Ford had done it before. Had a late build 94 with 93 motor mounts.
Thanks
Old 03-22-2010, 01:03 PM
snakedoc's Avatar
snakedoc snakedoc is offline
Ford With Out Tax Money
snakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to behold
i think around 4-99 but the big boys will be here soon.
Old 03-22-2010, 01:36 PM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
Engine build date?? I believe it was 12/7/98... You should have a late 99. Go out and count the bolts on the turbo compressor housing. 4 bolts = early, 5 bolts = late.
Old 03-22-2010, 01:48 PM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
Chassis cutoff for early/late was 3/99 I believe.
Old 03-22-2010, 02:10 PM
Izzy351's Avatar
Well, go out and count the bolts and come back and let us know...
Old 03-22-2010, 04:03 PM
PwerStroke99's Avatar
PwerStroke99 PwerStroke99 is offline
PwerStroke99 has a very good reputation on FTE.PwerStroke99 has a very good reputation on FTE.PwerStroke99 has a very good reputation on FTE.
Quote:
Mine must be a freak! 2/99 build, overall a late 99 truck
Old 03-22-2010, 04:08 PM
Quote:
Like I say, I 3/99 might not be right. I won't argue the part about you (or your truck) being a freak
Old 03-23-2010, 09:00 PM
jt371's Avatar
Compressor side has 5 bolts.
Like I said it has (had) the late 99 airbox, had foil on the drivers side boost tube.
Just was curious about the chassis. The first bushing kit I bought and sent back, they called me up and said it was the correct one for my truck. I told it was not the correct one and they didn't stock the one I needed, and asked them to credit me. Which they did.
Old 03-23-2010, 09:37 PM
Franko72's Avatar
Franko72 Franko72 is offline
Molon Labe
Franko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud of
after 12/??/98 is the late 99 engine
after 3/15/99 is late chassis
So you should have a late 99 engine, and an early 99 front end.
I THINK?????
Old 03-23-2010, 09:41 PM
canister's Avatar
canister canister is offline
canister is starting off with a positive reputation.
I THINK?????
Where do you find the chassis date? I have 3/99 on my doorjam, where is there a specific date?
Old 03-23-2010, 09:46 PM
Izzy351's Avatar
You definitely have a late 99 engine... The chassis part I have no idea about.
Old 03-23-2010, 10:26 PM
Franko72's Avatar
Molon Labe
Quote:
Im not sure Chris. We were talking about build dates on another thread a few days ago.
http://www.ford-trucks.com/forums/94...ml#post8660603
Old 03-23-2010, 10:29 PM
Franko72's Avatar
Molon Labe
[quote=rat49f6;8660016]The confusion lies in the fact that they changed engine configuration in jan and they changed the front suspension configuration in mid march.
Old 03-23-2010, 10:42 PM
canister's Avatar
Thanks Frank. Just curious about the chassis date because I believe my engine build date is 3/4/99, I'll have to check tomorrow.
Old 03-23-2010, 11:05 PM
Franko72's Avatar
Molon Labe
Do you mean the door sticker build date is 3/4/99. I believe that would be your chassis build date. Im not sure where the engine build date is located.
Which brings up a good question....Since International built the engines, but Ford installed them. Did the engines come from Navistar with the late 99 equip, bigger turbo, injectors...ect, or did Ford install these items on the line?
I know its kind of obvious by looking at the engines the difference between the early and lates, but if Ford did infact install the turbo, injectors and such, then the assembly date of the engine really wouldn't matter. It would be the date that Ford made the switch on the line as to if you have a late or early engine (3/15/99 ???)
Get where im going?
Sway Bar Bushings Irish19614x4 1999 to 2016 Super Duty 8 01-16-2016 06:19 PM
Sway bar problems brichert 1999 - 2003 7.3L Power Stroke Diesel 9 03-22-2015 10:15 AM
Front sway bar bushing (NOT end link) replacements truckfella Modular V10 (6.8l) 5 10-19-2014 06:44 AM
E99 F350 dually front ball joints, leaf spring and shackle bushings Petik 1999 to 2016 Super Duty 3 03-11-2014 09:52 AM
Energy Suspension Bushing Update AllaboutMPG 1999 - 2003 7.3L Power Stroke Diesel 5 09-29-2013 10:44 AM
Tags
1999, 73, 99, 99f350, build, date, diesel, difference, early, end, f350, ford, front, late, motor, parts, swap, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
