When was the cut off for early/late 99? - Page 2 - Ford Truck Enthusiasts Forums
Old 03-23-2010, 10:08 PM
canister's Avatar
canister canister is offline
canister is starting off with a positive reputation.
Quote:
Originally Posted by Franko72 View Post
Do you mean the door sticker build date is 3/4/99. I believe that would be your chassis build date. Im not sure where the engine build date is located.
Which brings up a good question....Since International built the engines, but Ford installed them. Did the engines come from Navistar with the late 99 equip, bigger turbo, injectors...ect, or did Ford install these items on the line?
I know its kind of obvious by looking at the engines the difference between the early and lates, but if Ford did infact install the turbo, injectors and such, then the assembly date of the engine really wouldn't matter. It would be the date that Ford made the switch on the line as to if you have a late or early engine (3/15/99 ???)
Get where im going?
3/4/99 is on my engine VC.
Old 03-23-2010, 10:14 PM
Franko72's Avatar
Franko72 Franko72 is offline
Molon Labe
Franko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud of
ok, so your truck and engine are 3/99.
Ill have to check mine tomorrow, my truck is a 8/98, im curious to see when the engine was built. obviously on or before that date. but still curious.
Old 03-24-2010, 06:22 AM
jt371's Avatar
jt371 jt371 is offline
jt371 is gaining momentum as a positive member of FTE.
Thanks everyone. That was what I was curious about. I have a late motor, early chassis. I like to know the details about my trucks anyways, but with early and late parts I want to know the correct ones to order if I have to.
Thanks again to all.
Old 03-24-2010, 11:42 AM
TRL WGN 1 TRL WGN 1 is offline
TRL WGN 1 is starting off with a positive reputation.
hey jt, welcome to the 2/99 build date club. I like to call my truck a 99.25 because just as yours, it has the late 99 engine with early 99 front axle
btw, where did you get the correct bushings? have a part # you would like to share? Mine clunks, of course.
Old 03-24-2010, 05:44 PM
Franko72's Avatar
Molon Labe
Ok, my engine build date is the same as the body...8/98
I guess Navistar was building engines as fast as Ford was building the trucks.
Old 03-24-2010, 07:47 PM
jt371's Avatar
TRL WGN 1 - So since it is an early front end does it have a Dana 50 or 60? I haven't looked at the tag on the diff cover yet. The bushing kit if from Energy Suspension 45-2587. I believe I got them from LMC Truck.
Old 03-25-2010, 09:21 AM
not sure on the 50 vs 60. I haven't read the tag either
Old 03-25-2010, 10:07 AM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is online now
PREMIUM SPONSOR
Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.
All the front ends are Dana 50's until you get up to 02-03 when the F-350's had Dana 60's.
Old 03-26-2010, 08:38 AM
SailCO26's Avatar
SailCO26 SailCO26 is offline
SailCO26 is starting off with a positive reputation.
Same boat here: Jan 99 biuld - E99 front end, 99.5 engine. I like the 99.25, I'll have to adopt that!
Old 03-26-2010, 09:00 AM
Quote:
figured that was more fitting than the common 99.5
unless ours are 99.5's and the others are really 99.75?
Old 08-29-2014, 07:12 PM
CampSpringsJohn's Avatar
CampSpringsJohn CampSpringsJohn is offline
CampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputation
This thread should be a sticky! People trying to figure out if they have an early or late 99. And, some actually have a little of both! Glad I found this thread!
Sway Bar Bushings Irish19614x4 1999 to 2016 Super Duty 8 01-16-2016 05:19 PM
Sway bar problems brichert 1999 - 2003 7.3L Power Stroke Diesel 9 03-22-2015 09:15 AM
Front sway bar bushing (NOT end link) replacements truckfella Modular V10 (6.8l) 5 10-19-2014 05:44 AM
E99 F350 dually front ball joints, leaf spring and shackle bushings Petik 1999 to 2016 Super Duty 3 03-11-2014 08:52 AM
Energy Suspension Bushing Update AllaboutMPG 1999 - 2003 7.3L Power Stroke Diesel 5 09-29-2013 09:44 AM
Tags
1999, 73, 99, 99f350, build, date, diesel, difference, early, end, f350, ford, front, late, motor, parts, swap, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
