Minnesota Chapter Join Chapter, Leader: fordpower88
Tractor turbo swap
Old 03-22-2010, 11:18 AM
F-127's Avatar
F-127
F-127 is offline
Tractor turbo swap
Just thought I would make a new thread instead of fill up the BS thread with 15 pictures. Old turbo was definitely tired at nearly 7600 hours, worked hard many of those. New turbo really cleans up the smoke good. Backed out the fuel screw after the install and it smokes less than before. Only purchases to complete the install were: turbo, manifold, exhaust sleeve, manifold to turbo adapter. Not a truck but it is a Ford engine, one I wouldn't mind having in a truck either.
The candidate, Ford 9600, round screen on the front is a self cleaning radiator shroud from a combine.
Underhood view before
Old turbo and connections
Manifold, old to new. Picked a divided manifold from newer tractor.
Compressor comparison
Same picture as in the BS thread
Exhaust sleeve plate, bored on lathe to accept the larger exhaust sleeve.
Exhaust sleeve tested for fit
Manifold
T3 to T4 adapter
Turbo and connections
Another view
intake connections
Hood support back in place with heat shield
Old 03-22-2010, 11:25 AM
fordpower88's Avatar
fordpower88
fordpower88 is offline
Looks great Thomas!! Nice pics! Can you tell a big difference in power with the new one on there? I like the chrome stack on the tractor too!!
P.S. one of these days I will get you the pcm code of my '94 too.
Old 03-22-2010, 11:34 AM
F-127's Avatar
F-127
F-127 is offline
It's definitely noticeable. I had the compressor outlet clamp on the turbo snug but not tight and it blew it off when my dad was testing it out. I think I forgot to tighten it but I'm sure it was snug enough I wasn't expecting that to happen.
Old 03-22-2010, 12:53 PM
DieselCamper01's Avatar
DieselCamper01
DieselCamper01 is offline
Nice work on getting that to all work together.
Old 06-05-2011, 11:34 PM
twofiddy's Avatar
twofiddy
twofiddy is offline
Surprised ya didn't put the updated oil filter like on the TW's. We got rid of the cartridge one on our 8000 a few years ago and it makes oil changes a lot easier. BTW is the new exhaust manifold and turbo off a TW or 30 series? Love those Ford tractors
Old 06-06-2011, 11:35 PM
84-6.9L's Avatar
84-6.9L
84-6.9L is offline
I checked with the local NH stealer here wanted $248 for that little adapter, Id like to change mine too, but i need to rebuiled the master cylinder first and that kit alone is $160, man NH parts are spendy
Old 06-07-2011, 10:53 PM
F-127's Avatar
F-127
F-127 is offline
Well the old manifold was only used from the 8000-9600, anything newer than that has the new manifold style that I swapped in. Yeah we could probably upgrade that filter too, doesn't get too much hours or oil changes though, few too many tractors around. Since it was mentioned, I did some looking with the shortline product dealers for us and found that adapter. It can be had for sub-$100. If you have a local A&I products dealer you can get A-DKPN6882A, or from All State Ag Parts 115060.
avf100
06-13-2017 11:49 AM
proline69
Large Truck
02-17-2013 09:40 AM
80broncoman
Large Truck
45
08-11-2012 05:48 PM
keifer1122
General Diesel Discussion
18
03-16-2012 01:36 PM
TXstroker01
25
07-29-2010 10:56 AM
Quick Reply: Tractor turbo swap
