Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Minnesota Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Minnesota Chapter Join Chapter, Leader: fordpower88
  #1 (permalink)
Old 03-22-2010, 11:18 AM
F-127's Avatar
F-127 F-127 is offline
Garage is empty, add now
F-127 is starting off with a positive reputation.
Tractor turbo swap
Just thought I would make a new thread instead of fill up the BS thread with 15 pictures. Old turbo was definitely tired at nearly 7600 hours, worked hard many of those. New turbo really cleans up the smoke good. Backed out the fuel screw after the install and it smokes less than before. Only purchases to complete the install were: turbo, manifold, exhaust sleeve, manifold to turbo adapter. Not a truck but it is a Ford engine, one I wouldn't mind having in a truck either.
Click the image to open in full size.
The candidate, Ford 9600, round screen on the front is a self cleaning radiator shroud from a combine.
Underhood view before
Old turbo and connections
Manifold, old to new. Picked a divided manifold from newer tractor.
Compressor comparison
Same picture as in the BS thread
Exhaust sleeve plate, bored on lathe to accept the larger exhaust sleeve.
Exhaust sleeve tested for fit
Manifold
T3 to T4 adapter
Turbo and connections
Another view
intake connections
Hood support back in place with heat shield
__________________
Thomas H.
1997 F-250 4x3 7.3L Auto, 285/200%, Modded H2E, headstuds, 7.3 IC, Stealth Dual-HPOP, FASS, D60
1984 F-150 4x4 351W C-6, intake, exhaust, NO rust, the looker
1985 Mustang 302 T-5, GT-40P heads, intake, exhaust(for sale)
  #2 (permalink)
Old 03-22-2010, 11:25 AM
fordpower88's Avatar
fordpower88 fordpower88 is online now
MN Chapter Ldr
fordpower88 has a great reputation on FTE.fordpower88 has a great reputation on FTE.fordpower88 has a great reputation on FTE.fordpower88 has a great reputation on FTE.fordpower88 has a great reputation on FTE.
Looks great Thomas!! Nice pics! Can you tell a big difference in power with the new one on there? I like the chrome stack on the tractor too!!
P.S. one of these days I will get you the pcm code of my '94 too.
__________________
Troy
'01 F250 CC SB 7.3 PSD, 160,000 miles, PHP tunes, BTS Trans, 6.0 trans cooler, 6637 w/Petes cover, DiPricol gauges, WW-II, HPX, IH bellowed up-pipes, MKO 5" exh.
'04 Ford Explorer XLT, 4.0, 63,000 miles
  #3 (permalink)
Old 03-22-2010, 11:34 AM
F-127's Avatar
It's definitely noticeable. I had the compressor outlet clamp on the turbo snug but not tight and it blew it off when my dad was testing it out. I think I forgot to tighten it but I'm sure it was snug enough I wasn't expecting that to happen.
__________________
Thomas H.
  #4 (permalink)
Old 03-22-2010, 12:53 PM
DieselCamper01's Avatar
DieselCamper01 DieselCamper01 is offline
2001 Ford F-350
DieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to behold
Nice work on getting that to all work together.
__________________
Jay
2001 F350 Lariat CC LB 4X4, Various mods
http://www.roadsidehelpnetwork.org/
  #5 (permalink)
Old 06-05-2011, 11:34 PM
twofiddy's Avatar
twofiddy twofiddy is offline
twofiddy is starting off with a positive reputation.
Surprised ya didn't put the updated oil filter like on the TW's. We got rid of the cartridge one on our 8000 a few years ago and it makes oil changes a lot easier. BTW is the new exhaust manifold and turbo off a TW or 30 series? Love those Ford tractors
__________________
01 F-150 4x4 330 cid
82 F-250 4x4 351W cid
  #6 (permalink)
Old 06-06-2011, 11:35 PM
84-6.9L's Avatar
84-6.9L 84-6.9L is online now
1984 Ford F-250
84-6.9L is gaining momentum as a positive member of FTE.84-6.9L is gaining momentum as a positive member of FTE.
I checked with the local NH stealer here wanted $248 for that little adapter, Id like to change mine too, but i need to rebuiled the master cylinder first and that kit alone is $160, man NH parts are spendy
__________________
Keep our planet clean, when you fuel up please use the green handle.
84 F-250 6.9 with a boost from Hypermax.
87 F-150 5.0 The winter truck
68 F-250 CamperSpecial 390ci/NP435 Getting a Diesel!
75 9600 Tractor 401ci Blowin smoke in 300 ft bursts
Tom
  #7 (permalink)
Old 06-07-2011, 10:53 PM
F-127's Avatar
Well the old manifold was only used from the 8000-9600, anything newer than that has the new manifold style that I swapped in. Yeah we could probably upgrade that filter too, doesn't get too much hours or oil changes though, few too many tractors around. Since it was mentioned, I did some looking with the shortline product dealers for us and found that adapter. It can be had for sub-$100. If you have a local A&I products dealer you can get A-DKPN6882A, or from All State Ag Parts 115060.
__________________
Thomas H.
Tags
10, 1987, 30, 9600, difference, f150, ford, install, mustang, series, swap, tractor, tractors, truck, turbo, turbocharger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
