7.3l died while driving
Old 03-22-2010, 08:26 PM
medhvac's Avatar
medhvac
medhvac is offline
Im gona go out on a limb and say man that sounds like a dirty or bad IPR valve
Old 03-23-2010, 01:30 AM
Wiredoge4's Avatar
Wiredoge4
Wiredoge4 is offline
Checked the fuel and there is a a good stream coming out of the valve while turning it over. Also unplugged the ICP and the truck didn't run. No smoke or smell of diesel coming out of the tale pipe. Not able to hook up the AE tonight will try tomorrow.
Old 03-23-2010, 01:33 AM
Wiredoge4's Avatar
Wiredoge4
Is it possible to clean the IPR. They are expensive around $350.
Old 03-23-2010, 01:36 AM
BDalton's Avatar
BDalton
BDalton is offline
Might Help
New Page 0
Old 03-23-2010, 04:52 PM
Wiredoge4's Avatar
Wiredoge4
Can the fuel bowl heater cause the truck to stop running while driving?
I have ordered my own AE and should be here 3-24-10 so I will do the ICP,IPR test then. Does anyone know what I should look for. ICP pressure 500psi or above but what about the IPR duty cycle %. I also plan on pulling the IPR and cleaning it maybe tonight. Just need to find my 1 1/8 deep socket to do it.
Old 03-24-2010, 11:46 PM
Wiredoge4's Avatar
Wiredoge4
IPR duty cycle 64.8
ICP 158 PSI
RPM 169
MAP 12.9
ICP Volts .41
Battery 15.9-11.8
It looks like a bad IPR to me. What do you think.
Also new codes
B1359
B1302
P1690
P603
Old 03-24-2010, 11:57 PM
mustangrh68's Avatar
mustangrh68
mustangrh68 is offline
I have seen the injector driver do the exact thing. Truck just dies and will not start. This was on a 96 F-250.
Old 03-25-2010, 12:55 AM
Wiredoge4's Avatar
Wiredoge4
I have already put my IDM in my friends truck and it work fine. Its looks like a bad IPR or HPOP.
Old 03-25-2010, 07:24 PM
F350-6's Avatar
F350-6
F350-6 is offline
Your IPR maxing out at 64% is a good sign, or at least it's being commanded to max out in the right range. Have you tried unplugging the ICP and starting? Have you checked for any codes lately?
With an ICP below 500 psi, you will not start. The easy things to check first will be the wiring to the IPR and ICP to make sure there are no chaffed wires or brittle insulation. Also make sure the tin nut on the back of the IPR is snug and the soleniod isn't loose.
If you can find the parts, the next step really should be to block off 1 head at the HPOP (disconnect one hose from the HPOP and plug that line), then install a mechanical gauge in the head that is still connected and see how much pressure you can build on that head. You might want to unplug the CPS for this test or pull a fuse so the truck doesn't accidentally start on one bank. If you find one head builds good pressure and the other doesn't, it's likely bad injector o-rings on the weak side.
Of course try unplugging the ICP sensor first to see if that works. Also maybe see if your friend will let you swap any more parts around. If he's willing, I'd do that with the IPR before I threw money at one as a guess.
Old 03-26-2010, 01:39 AM
Wiredoge4's Avatar
Wiredoge4
So went ahead a took out the IPR tonight. It was really dirty. cleaned it up and Put it back in the truck and now for the first time in 5 years it started right up even at a temp of 33 degrees.
IPR duty cycle was high at first 20% and stettled down at 9%
ICP was at 1000psi and settled down at 500psi
ICP volts at .74
MAP at 12.9
Thanks for all your help Im sure I will be back. Truck is running smoother than ever. Thanks Clay at RiffRaff for the AE...
Old 03-26-2010, 12:30 PM
240spoke's Avatar
240spoke
240spoke is offline
Man thats great.... Thanks for posting the fix.... Now post a joyous burnout on you tube and give us the link...
Old 03-26-2010, 12:49 PM
Wiredoge4's Avatar
Wiredoge4
SO just to make sure it ran I tried it again this morning and it was 25 degrees out and it fired right up first try. I have been fighting the cold temp and not starting for years, it was easier to just plug it in, but I did the normal test, glow plugs replacing the glow plug and relay. I gave up. So for now I would tell people out there to clean up the IPR next if you have a cold start issue and it runs rough when warm. Cause if you dont years latter it will just shut down on you and the your scratchin your head. The good thing it led me to the IPR after this last time around. I also want to thank F350-6 for his help.
See YA next time....Cuz trucks don't run for ever.....
  #28
Old 03-28-2010, 09:28 AM
01 EXCURSION MORRIS's Avatar
01 EXCURSION MORRIS
01 EXCURSION MORRIS is offline
SUBSCRIBING
  #29
Old 03-28-2010, 10:17 AM
Kwikkordead's Avatar
Kwikkordead
Kwikkordead is offline
Great job there, Chris.
Reps sent for helping this guy.
  #30
Old 03-02-2014, 09:42 PM
kev03's Avatar
kev03
kev03 is offline
what and where is the ipr?
Quick Reply: 7.3l died while driving
