K&N Cold Air Intake Question/Help
Ok I went to order the K&N cold air intake kit and when ordering it, the prep. wanted to know if I wanted to order 2 Tornado Performance Booster to go with the cold air intake kit. I need 2 of them because I have duel intakes hoses. Would the Tornado Performance Boosters be worth getting and will it make any difference along with the K&N cold air intake? Any help or comments would be great!
Thanks again.
1996 Ford F250 7.5 V8
Thanks again.
Thanks again.
Thanks again.
There is this one site that did dyno on all those fuel savers an the tornado thing dose not work it makes it worse cuz it slows down the air flow. But i wounder if the tb spacer really works air raid looks like they make a good one. Another good thing to get is a trans commander earthier by banks or jet dont know what one is better both say they do the same thing. An bbk makes a 61mm tb that is another good bolt on. Sorry got carried away.
Thought you guys might be interested in some of my previous posts.
FIPK: https://www.ford-trucks.com/forums/4...ilter-mod.html
Air Horns: https://www.ford-trucks.com/forums/4...e-tonight.html
on
https://www.ford-trucks.com/forums/1...set-screw.html
no but see the above link i have a separate thread going. it appears that the top part of the bolt broke off and it is not able to be adjusted but the PO has a washer taped to the stop plate. I took the washer off but the idle speed sits at about 600 rpm. it accelerates fine but on decel it sort of decelerates slowly until about 1000 rpm then snaps back to 600 rpm. i think that problem is actually with the little link arm (does anyone have part # for that?) it is not that bad but my only concern is that i dont want the butterfly valves to get damaged if they are getting too close to the throttle body tube. i guess how close is too close? haha does any of that make any sense?
Big_Blue83
12-06-2018 04:33 PM
annaleigh
04-29-2018 06:59 AM
Big-old-460
314
09-21-2016 10:38 PM
thechassisman
09-21-2015 11:56 PM
