Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 03-21-2010, 07:29 PM
pickncrew's Avatar
pickncrew pickncrew is offline
Garage is empty, add now
pickncrew is starting off with a positive reputation.
Cool No Spark - '95 F-350 5.8L
'95 F-350 5.8L / E40D
Will not start - fuel pressure is fine, there is no spark seen when I remove a spark plug, ground it and crank over the engine. I have:
- Ohm'd out the coil and then swapped it with a known good one just to make sure.
- Swapped the ECM relay with the one from the horn with no change.
- Disconnected the ECM and still there is no spark.
- Had the FFI module (ICM) checked at auto parts store - tested good.
At this point is there anything else it could be or anything I could rule out besides the PIP / distributor?
  #2 (permalink)
Old 03-21-2010, 07:36 PM
subford's Avatar
subford subford is offline
subford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to behold
It does sound like the PIP sensor.
__________________
95 F150 302 4R70W EB EX-CAB
94 F53 460 E4OD COACHMEN SANTARA RV
83 F150 Flare Side 351W AOD
77 F250 351M-2V NP 435/4 Speed 4X4
subford@gmail.com
Bill K, Kansas Chapter
  #3 (permalink)
Old 03-21-2010, 07:46 PM
pickncrew's Avatar
Quote:
Thanks Subford... your posts from previous threads have been most helpful; you are a huge asset to FTE. Not sure if the PIP is more likely to fail all at once or if there's any significance to it, but about a month ago my truck wouldn't start one day and then it did the next day. This time I drove it around town one day and the next day it wouldn't start but still won't start that's why it was time to start troubleshooting. Is it possible for the pip sensor to get weak and work one day and not the next?
  #4 (permalink)
Old 03-21-2010, 10:13 PM
subford's Avatar
Most of the time they will not start. There are also ones that do start and run for a while then the engine will quit after a few miles. It will not restart for a while then the engine will start back up and then quit again after a few more miles. I have not heard of one going bad the way you described.
It sounds like you have checked everything else but make sure the plug that plugs on to the coil is good as I have that plug cause this problem also. Check with a test light that you have power on both small wires on the plug with the key on.
__________________
subford@gmail.com
  #5 (permalink)
Old 03-22-2010, 05:23 PM
pickncrew's Avatar
Just measured and yes there is voltage on both. Seems to be initially be around 12vdc and then counts down. Looks like an aftermarket reman distributor with cast iron gear is just under $100.
  #6 (permalink)
Old 03-24-2010, 08:11 PM
pickncrew's Avatar
hmm... new distributor did not do it, now I'm perplexed and wondering where I went wrong. Anything else to check Plug wires are less than two years old I guess I could check the coil wire.
  #7 (permalink)
Old 03-24-2010, 09:48 PM
subford's Avatar
I would go ahead and replace the Black ICM with another Black ICM. Make sure they do not sell you a Gray one.
If that does not do it then itwould have to be wiring. Either you have a wire shorting to ground or an open wire.
I hope you are leaving the PCM Computer unplugged during all of these test for spark.
It is also possible that they sold you a bad distributor. One poster said he had to take three or four back before he got a good one.
Here are diagrams of your system "H" if you need them.
Click the image to open in full size.
__________________
subford@gmail.com
  #8 (permalink)
Old 03-24-2010, 10:07 PM
pickncrew's Avatar
But the ICM tested good... also does the PCM = ECM ? The first time I checked for spark it was plugged in but then subsequent test I had it unplugged. I should see spark at my #1 plug when cranking the engine and shorting case to ground right? Thanks again.
  #9 (permalink)
Old 03-24-2010, 11:07 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
The ICM's are hard to test. They can pass a test and fail on a vehicle.
However, more often than not...the vehicle will start but once it gets hot it'll loose spark.
Yes you should, but that isn't the best way to do it. Go ahead and pick up a spark checker next time you're at the auto parts store. They're cheap and are a reliable way to make sure you have no spark.
I've seen a lot of people chase problems for a long time based on false initial information.
__________________
Justin
95' F-150 XLT 4x4, 393ci stroker, 5 spd, 6" lift/35s
  #10 (permalink)
Old 03-25-2010, 06:35 AM
subford's Avatar
Quote:
ECM was used on our trucks in the late 1970's to the mid 1980's. Then we had the EEC Computer from the late 1980;s through some early 1990's trucks. The PCM Computer started about 1990 in some trucks and all by about 1993. The PCM is still used today on new truck as far as I know.
All Three had different jobs to do and that is why they had different names.
Emission Control Module (ECM): The module that controls emissions.
Electronic Engine Control (EEC): The system that provides electronic control of engine operation plus also controls emissions.
Powertrain Control Module (PCM): The module that controls the EEC system plus Transmission Control.
As MustangGT221 said yes you should have spark but it is best to use a spark tester.
__________________
subford@gmail.com
  #11 (permalink)
Old 03-25-2010, 10:08 AM
PCM and ECM are interchangeable acronyms.
PCM is powertrain control module and ECM is engine control module. It refers to the brain of the system, in our case the EEC, electronic engine control.
There is no emissions module.
__________________
Justin
  #12 (permalink)
Old 03-25-2010, 10:58 AM
subford's Avatar
Just going by the FORD factory shop manuals and that is what they say.
You must have a different source.
__________________
subford@gmail.com
  #13 (permalink)
Old 03-25-2010, 06:16 PM
pickncrew's Avatar
I'll get a proper spark tester and also go step by step, checking the wiring between the various components.
  #14 (permalink)
Old 03-28-2010, 10:09 PM
pickncrew's Avatar
The problem was the PIP/Distributor. My other problem is when I swapped out the coil with a "known good one" it apparently wasn't. I left it in there and swapped the dist. and it still did not work. I unplugged the coil connector and ran a wire from the red lead to ground through a 5amp fuse and it blew so I know I had power at the coil and after wiring checked good decided to put the original coil back in there and it started right up.
thanks for everyone's help on this...
  #15 (permalink)
Old 03-29-2010, 10:51 AM
It can be a PITA. The information Ford used in-house...or what might be in a printed manual...is not mainstream.
I've never seen anyone differentiate between a 'pcm' and 'ecm'....same thing...refers to the engines computer. The main difference only comes in that later vehicles used the computer to shift the tranny where early ones did not. That may be the use for the change in term...but regardless...they're interchangeable amongst the general public. PCM and ECM are refering to the vehicles engine management computer. Regardless of if that computer shifts the transmission or not, it's still an engine management computer. It's not a totally different piece of equipment.
I'd still like to know what they really are refering to when they say 'emissions module'. Our trucks don't have that...and if they do...than they're refering to something other than a computer box such as the ECM and that is just confusing.
BTW, there are better ways to check for power at the coil! Use a test light or voltmeter! Voltage spikes in an EFI system are your enemy!
__________________
Justin
Tags
1994, 350, 58, 58l, engine, ford, ground, icm, interchangeable, loses, module, problem, replace, spark, starts, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
