Surging? - Ford Truck Enthusiasts Forums
Surging?
Old 03-21-2010, 06:27 PM
deercreek1's Avatar
deercreek1 deercreek1 is offline
deercreek1 is starting off with a positive reputation.
Surging?
2005 F350 with 170,000 miles. Last week it began surging while driving at 60 mph. Not constant but every 10 milkes or so it would surge or hickup. I thought it was fuel filters so I switched those and no change. At times at a stop sign it will jump a bit almost like I hit the gas a little. The turbo was replaced at 105,000 and the EGR was disconnected at that time. I do run a Bullydog for economy and did flash back to factory and still had the same problem. Any ideas?
Old 03-21-2010, 08:27 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
try unpluging the epb see if it goes away, if it does suspect possible concern with the ebp sensor, vgt silenoid or turbo sticking.
if that does not modifiy the concern plug it back in and try the icp sensor, if that modifies the concern possible icp sensor,sensor connector or dummy plug/ standpipe o-ring.
can oyu moniter ipr% at hot idle normal woul dbe about 22-24% readings near 30% would also indacte a high pressure concern.
Old 03-21-2010, 08:55 PM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
Exhaust Back Pressure Sensor (EPB) need to be cleaned out occasionally.
Same with VGT turbo vanes, which rust and stick.
Have temporarily solved both of the above with resetting code and "italian tuneup".
I have issues now with surging (almost always at idle, after engine fully warm, as I pull into a parking spot).
On the coldest days (20F or lower), have pulled EBP P0472 (EBP sensor circuit low) error, but inevitably it went away if I just reset the code.
If I get engine hot, I have had P0299 (Turbo Underboost) which puts vehicle into limp mode, so I clear the code, and it runs fine again.
Right now, best guess is:
A) EGR Valve due for cleaning.
B) EBP due for cleaning
C) Turbo due for cleaning.
Surging do not occur at all RPMs in my case, which rules out more serious problems.
lakewood's Avatar
lakewood lakewood is offline
lakewood is gaining momentum as a positive member of FTE.
My 05 had similar problems, but at idle it would idle really choppy, sounded like a bad injector, but it was my ICP sensor, hook your truck up to a scanner and see what the ICP is reading, it should have 1.2 volts, my truck had .82 volts so i replaced the ICP and it was fine.
Old 03-21-2010, 09:02 PM
Oh... anyone working on their sensors....
Clean contacts.. check wiring... etc.. before you decide anything is bad.
See link in my signature for details.
Old 03-22-2010, 10:25 AM
deercreek1's Avatar
I also did have an DTC that said fuel injector low pressure. This went away and has not come back. Truck is going in today.
Old 03-26-2010, 06:03 PM
deercreek1's Avatar
Installed a new EGR and found out through driving with mechanic while on laptop that I have a short somewhere in the injetcor wiring harness. We gently pulled the harness while it was running to attempt a burp while on the laptop. No burp and actually problem is gone for now. Anybody have any suggestions as to where the short most likely would be? Common rubbing location on the 05's?
Old 03-26-2010, 06:21 PM
Quote:
Originally Posted by deercreek1 View Post
I Anybody have any suggestions as to where the short most likely would be? Common rubbing location on the 05's?
Think someone has figured that out.. and it is here:
http://www.dieselpowermag.com/tech/0.../photo_19.html
Old 03-26-2010, 06:26 PM
deercreek1's Avatar
I will check out the link - Thanks!
Old 05-04-2010, 08:48 PM
F 250 6 liter's Avatar
F 250 6 liter F 250 6 liter is offline
F 250 6 liter is starting off with a positive reputation.
lack of power
Hello Deercreek any luck on the issue yet I am having the same symptons? Thanks
Engine Surge with Defrost or Mix - Problem Solved! Mystery Persists... Tim Hodgson 1978 - 1996 Big Bronco 12 01-06-2015 01:43 AM
Engine Surge with Defrost or Mix Tim Hodgson 1987 - 1996 F150 & Larger F-Series Trucks 7 12-21-2014 11:26 PM
2004 Ford Ranger 2.3L Surging 2valvekid Ranger & B-Series 2 09-25-2011 09:06 AM
2005 Idle Surge ClubDrof 6.0L Power Stroke Diesel 11 11-17-2004 09:51 PM
surge acousticbill 1978 - 1996 Big Bronco 3 09-09-2003 11:26 AM
Tags
60, code, diesel, driving, dtc, e350, ford, liter, p0472, powerstroke, reset, surges, surging, truck, v10, vgt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
