Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-20-2010, 08:04 PM
tony1947 tony1947 is offline
1947 Ford F-100
tony1947 is starting off with a positive reputation.
Question flathead lifters pitted
I just started tearing down my 52 V8 , it looks like it was a real oil burner , most of the valves were not sealing good and oil/sludge was knee deep under the intake manifold . I got the valve assemblies all out , good fun there! And then when I pulled out the lifters 4 of them were badly pitted from the top to were they come up to open the valve . I didn't see any water in there to rust them ,they look clean but pitted . What could cause this? Is it something to worry about? Some of the valve guide were worn , I could wiggle the valves a bit. Engine was never stuck like most are ,turned over ok, just some of the vaves were stuck ,PB blaster ,time and a rubber hammer loosen them up fine. tony
  #2 (permalink)
Old 03-20-2010, 11:16 PM
fixnair's Avatar
fixnair fixnair is offline
Garage is empty, add now
fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.
fixnair
Pitting of the lifter cam face is usually caused by acidic oil. Previous owner probably did not change oil often enough.
__________________
2002 F350 7.3 Ltr. 6sp.DRW 270K miles, 13' service body
1952 F1 flathead Project Truck
2008 Lincoln MKX
need thermostat housing & cab 4 project
Tags
flathead, ford, intake, lifter, lifters, manifold, pitted, specifications, tappets
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
