1948 ford truck engine question - Ford Truck Enthusiasts Forums
Old 03-19-2010, 06:06 PM
cowboy1997 cowboy1997 is offline
cowboy1997 is starting off with a positive reputation.
I have a 1948 ford flathead straight 6 engine in a ford 8n tractor it was called a funk conversion. I'm looking for information on what the engine is. I'm trying to find a water pump for it. thanks for any help.
Old 03-19-2010, 06:37 PM
4tl8ford's Avatar
4tl8ford 4tl8ford is offline
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
Mac may have some info on his site.
The Ford Flathead V8 Site
Old 03-22-2010, 09:20 PM
jbrittonjr's Avatar
jbrittonjr jbrittonjr is offline
jbrittonjr is starting off with a positive reputation.
Could it be the 6 cylinder 226?
Old 03-22-2010, 11:23 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Can you find a cast part number on the head - should be something like 7HA 6050
Old 03-23-2010, 07:03 AM
jbrittonjr's Avatar
I see 0HA6050 on one, 7HA6050-C2 on another.
Old 03-23-2010, 09:25 AM
Quote:
I don't know the 6's very well, but following Ford's quirks I'd say you have a '50 and a '48/49. The C2 suffix is a designation for running changes Ford made to the original design in 1947.
Back then, the first letter is usually the date casting started on that design and continues for several years until a significant change is made that requires a new code.
The significant detail is the H that identified the version of 6 cyl as 48-51. Prior to 48 the 6 cyl was the G model.
Old 03-23-2010, 05:06 PM
jbrittonjr's Avatar
226 waterpump.
If this is the water pump you're looking for there are characters & numbers on the body:
119612,
SCC02 and
7HA8505
WTB: 1948 1949 1950 FORD F2 F3 REAR FENDERS WingingIt74 WTB - Parts & other 2 07-23-2013 08:43 PM
1948 ford f68 ? Cody_1948 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 09-16-2011 02:09 AM
1948 M-68 Build corner27 1948 - 1956 F1, F100 & Larger F-Series Trucks 19 09-28-2010 10:20 AM
1948 f1 wheels diannathomas 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 10-31-2007 12:11 PM
1948 "One-Ton" Dually M6EV139445 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 05-01-2007 08:25 PM
Tags
1948, 226, 48, 7ha8505, engine, f1, ford, fordtruck, original, pennsylvania, pump, replacement, specs, truck, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
