Frame bolts
Old 03-22-2010, 05:29 PM
Stephen67's Avatar
Stephen67
Stephen67 is offline
Frame bolts
I took out a couple rivets today to prepare for shortening my wheel base. The hole was about .405-.415" or so, and the same with the rivets (though they possibly did get messed up due to having to be hammered out)
My question is, I'm going to have to drill everything out to 1/2" aren't I? It's a little under 7/16" (.43), but I can't find any grade 8 bolts in town that size, 3/8" is at .375. Am I correct in thinking that if I use 3/8" bolts that I will have too much play? Granite thats about .02" around the bolt. Anyone know?
Thanks
Old 03-22-2010, 05:44 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
7/16' or 1/2' - 3/8 will allow too much slop - try Granger or MacMasters and Carr for bolts
and Lock Nuts in grade 8
Old 03-22-2010, 06:07 PM
bobj49f2's Avatar
bobj49f2
bobj49f2 is online now
Received 2,059 Likes on 804 Posts
I'm replacing the front crossmember in my '37 Buick, I'm going to 1/2" button head bolts and locking flange nuts. The button heads will look pretty close to the rivets I drilled out. The button bolts I have I got from the local well stocked hardware store and the nuts from Fastenal. You can get the same from McMaster but you have to buy in larger quantities than what I needed. I was told the button heads are grade 8, at least they are better than standard.
1/2-13 Large Flange Top Locknut Grade F (GR 5) Steel Zinc | Fastenal
I searched the HAMB forum and posted a question about rivets vs. bolts. As usual the HAMB replied with a lot of information. When using rivets you can get away with some slop in the holes because as the rivets are mashed down they will fill voids. Using bolts aren't as forgiving. It was suggested to me to ream the holes to 1/2", I just going to use a 1/2" drill. I plan to insert a couple of tapered pins in the holes before drilling and then install the bolts one at a time as I drill out the next hole to help keep everything aligned.
Old 03-22-2010, 06:09 PM
needhelp49's Avatar
needhelp49
needhelp49 is offline
im surprised your not putting rivets back in if someone wouldn't of walked off with my forge thats the way i would a gone
Old 03-22-2010, 06:19 PM
havi's Avatar
havi
havi is offline
I'll have the Roast Duck
post delete
Old 03-22-2010, 06:21 PM
bobj49f2's Avatar
bobj49f2
One thing I forgot, some big truck guys chimed in on the HAMB and said they used bolt type rivets, called Huck rivets:
The big problem with using these is you have to buy a $1500 tool to install them.
Old 03-22-2010, 06:24 PM
bobj49f2's Avatar
bobj49f2
Originally Posted by havi
Maybe a step-drill will make it easier, than trying to line up a 1/2" bit into a 13/32" hole, as it will grab.
Scott, the problem with a step drill, at least the ones I have, they probably won't go deep enough before you engage the next step. You'd have to attack the hole from bot sides. I might work if you can easily get at both sides but the holes I am doing are accessable from top a lot easier than the bottom. I would go with a good 1/2" with a side handle.
Old 03-22-2010, 07:56 PM
Stephen67's Avatar
Stephen67
Thanks guys. I found some 7/16" in town, I'll just drill out the holes a little bit more. Had to get a little longer bolt than I'd probably normally use, but I thought it be a wise idea to have the part actually in the hole, where all the stress would be, thread free. Seems like it would defeat the purpose if crushable threads where in the hole.
I suppose I could use rivets, but they loose their heads when removed so I'd have to forge a new set and right now thats just one more thing, especially with 32+ of them...
Also, I'm planning on swapping axles later on in the build, and if I don't use the same suspension I may be cursing up a storm when I have to do all that again... thus the bolts.
Bob, do you already have all the holes in the frame as well? I had planned to move the axle up and once aligned just bore out and drill the frame hole at the same time. Sorta do one on each side, bolt it down, then do another. Make it easier to keep it all where it should be I'd think.
Old 03-22-2010, 08:12 PM
needhelp49's Avatar
needhelp49
you can buy 3/8ths rivets from centaur forge but if its coming apart again bolting is good
Old 03-22-2010, 08:17 PM
52 Merc's Avatar
52 Merc
52 Merc is online now
Received 2,440 Likes on 1,390 Posts
I think that's a great idea, Stephen. Just be 100% sure that the nut doesn't bottom out on the bolt shank, where it wouldn't get tight against the frame, but be very tight while turning, if you know what I mean.
Old 03-22-2010, 08:33 PM
havi's Avatar
havi
havi is offline
post delete
Old 03-22-2010, 08:38 PM
Stephen67's Avatar
Stephen67
Yep I checked that quite a bit. Had to measure how much of the shackle and frame there was (about 1/2"), then after washers and lock washers it's plenty in the clear. They're 2" bolt, I'm sure 1 1/4" would have done the trick but I wanted that unthreaded part. Besides they can be cut if I feel the need. The fits probably going to be tight enough I'll have to hammer them in, least a little tap-tap-tappa-roo.
Think I should use washers on the shackle side as well? lol it's not going to look as clean as the rivets did, but eh.
Old 03-22-2010, 09:29 PM
52 Merc's Avatar
52 Merc
A tap-tap fit in your application is a good thing. I wouldn't use a washer on the bolt head side. The shackle casting is plenty heavy to distribute the load. Adding a washer there would create more problems than help, imo.
Old 03-22-2010, 09:38 PM
Stephen67's Avatar
Stephen67
Yeah I think you're right on that, but I figured I'd ask, keeps me from wondering about it every time I look at it. I'm just use to using washers everywhere on everything, ha.
Old 03-23-2010, 03:08 AM
truckdog62563's Avatar
truckdog62563
truckdog62563 is online now
Marmon-Herrington Man
Quick Reply: Frame bolts
