Starter keeps turning with key off - Ford Truck Enthusiasts Forums
Old 03-19-2010, 01:11 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Posting for a friend.
He has an '86 F250, and claims his starter keeps turning the engine with the key off, only way to stop it is by disconnecting the battery!
Electrical problem for sure, but from where? Gotta be in the ignition switch?
Old 03-19-2010, 03:37 PM
ccecilm2 ccecilm2 is online now
ccecilm2 is starting off with a positive reputation.
My first guess is a bad fender mounted solenoid/relay. I had a lot of problems with that on my 84 f150 until I broke down and bought a Motorcraft brand. I went through 3 off brand versions within 2 years. If you will do a search for "fender mounted solenoid" (with the quotes) I think you will find a test procedure for it.
Old 03-19-2010, 08:34 PM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
Yep, 99% of the time, this issue is isolated to a faulty starter solenoid. The contacts inside can "weld" themselves together.
Every once in a while, there's another issue that causes it. Usually a short in the switch, or other switch fault.
Old 03-19-2010, 08:37 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Pull wire #5 off in the diagram above. If it still keeps cranking with this wire off, it's not the keyswitch.
Old 03-19-2010, 10:06 PM
Archion's Avatar
Archion Archion is offline
Archion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputation
If it is the solenoid after pulling the wire off, check the battery, low cranking voltage is the usual cause for cooking the solenoid.
Old 03-20-2010, 01:08 AM
fepowerguy8's Avatar
fepowerguy8 fepowerguy8 is offline
fepowerguy8 is gaining momentum as a positive member of FTE.
I just had this happen on my 86 and it was the solenoid on the fender, and it took out my starter, still fighting the parts supplier on this for a new starter.
Old 03-20-2010, 07:36 PM
rustybaker rustybaker is offline
rustybaker is starting off with a positive reputation.
Probably a bad solenoid, but Ford does have a history of weak return springs in the ignition switch.
Old 03-20-2010, 10:09 PM
Thanks everyone, bad starter solenoid.
All fixed and working great!
Old 07-29-2010, 01:58 PM
hkyler123 hkyler123 is offline
hkyler123 is starting off with a positive reputation.
I have a similar problem.
Ok, I have a 1997 f-150 xlt 5.4L triton v8, about 2 months ago I started it up and the starter would not disengage, so i would have to shut the truck off and try it again and it would stop, just about 2 weeks ago I decided to do something about it, so I changed out both starter solenoids and my ignintion switch. but i still get the same problem, but now it turns over everytime the battery is hooked up (even without the keys out of it). I ran some tests on the starter relay fuse and some other wires. The power to the starter relay fuse is correct, (only power when key is all the way on) but even when there is no power to the fuse there is continuous power to the main power cable on the starter mounted solenoid, and im about to go crazy, i've tried everything. Can somebody help me????
Old 07-29-2010, 11:07 PM
Franklin2's Avatar
Did you read the above posts? Do you have a wire that looks like #5 in the above diagram?
Old 08-01-2010, 11:57 AM
yup i did what the diagram said i replaced my solenoid, the relay, the relay fuse, and the ignition and it still does it...
Old 08-01-2010, 11:59 AM
and yes it did turn over with the ignition wire pulled off
Old 08-01-2010, 12:45 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
#5 in the diagram is NOT an ignition wire per se, it is the wire that, when power is applied to
it, tells the starter solenoid to provide current to the starter motor. Red/blue stripe (at least
on gas engines) and should have power ONLY when the key is in the START position. Pull
that wire off the solenoid and do some tests.... that wire should have power only in START,
if there is power at any other time then the column-mounted ignition switch is suspect
(assuming no wiring problems between those two devices).
It sounds like you've got that much figured out... if there is power to the starter motor
anyway, that relay is defective and is sticking.
Old 08-01-2010, 02:30 PM
Franklin2's Avatar
Quote:
Yep, another stuck relay. I remember long ago someone figured out they were ruining the new solenoids by over-tightening the large nuts on the relay. The whole stud was turning inside the unit when they tightened it, making it stick. Other than that, it's just lousy quality solenoids(relays).
Old 08-01-2010, 06:58 PM
well ive put on 3 different relays while not snugging up the nuts and the problem is still there and i also had my alternator tested at napa and they said it is perfectly fine.
Starter stays on with key on and engine never turns off armstrongz34 1973 - 1979 F-100 & Larger F-Series Trucks 22 10-18-2013 04:37 PM
starter keeps turning after key is off 1SheldonW 1999 to 2016 Super Duty 3 03-12-2013 09:12 PM
starter problems DonnyDoLittle 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 07-13-2011 12:07 PM
86 bronco starter will not disengage jhoopman86 1978 - 1996 Big Bronco 6 08-04-2010 10:30 AM
Starter keeps turning ridecolby 1987 - 1996 F150 & Larger F-Series Trucks 1 08-11-2009 08:51 PM
Tags
1984, 1990, 2000, cranking, f150, ford, ignition, key, off, release, starter, stster, switch, truck, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
