Body Mount Replacement - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 03-19-2010, 12:05 AM
longjohn's Avatar
longjohn longjohn is offline
longjohn is starting off with a positive reputation.
I need to replace the body mounts in my Ex. How do you do it? Does anyone have any tips or pointers. Thanks.
Old 05-15-2010, 06:02 PM
Dakrri's Avatar
Dakrri Dakrri is offline
Dakrri is starting off with a positive reputation.
Has anyone actually replaced the front mounts on an X? I removed mine
today and had to cut away the rubber part on the bottom side so I could get a wrench on it. The nut was completely rusted away. What a pain....
I been to two parts stores and you cannot buy a new mounting kit from them. I guess I'll have to go to ford dealership on Monday.
Questions:
1. There is a larger rubber mount between the frame and the body, how do I get that out of there? And do I even need to replace that part?
2. Can I just buy a new bolt (mine is rusted bad) and the rubber nut/washer/mount thing-ee that the bolt threads into on the very bottom of the frame?
3. Do both sides need to be done? Mine only clunked on the drivers side.
Thanks Dale
Old 05-15-2010, 06:48 PM
ZBIGBIG19TH ZBIGBIG19TH is offline
ZBIGBIG19TH is gaining momentum as a positive member of FTE.
According to my Ford dealer ,mounts are sold as one unit.90 $ each.
YC3C-1000155-GA and YC3C-1000154-AA.
You can change them on one side only if needed.
Old 05-15-2010, 07:41 PM
Dakrri's Avatar
Thanks ZBIGBIG19TH
Does anyone know how to remove the larger rubber mount between the frame and cab ... or maybe that doen't get replaced?
It is sandwiched in there and I would need the to lift the body 1/2-inch (??) to remove it.
Thanks
Dakrri
Old 05-16-2010, 12:23 PM
Yes you have to jack up the body.
This is according to shop manual:
1)"Raise and support the vehicle body enough to allow the removal of the unserviceable upper body mount."
2)"when removing upper body insulators,all other body mount support bolts must be loose before raising the vehicle cab to prevent permanent structural damage from occurring to the vehicle cab."
3)"during installation do not use any lubricants on the body mounts or fasteners."
Note:
"Do not reuse body supporting fasteners. New fasteners must be installed for each fastener that has been removed or loosened."
Well according to Ford it's not as easy as it looks but.......
I'm sure ford technicians do not follow all this to change 1 body mount.
But, what do I know?
Old 05-17-2010, 07:30 AM
Dakrri's Avatar
I used a floor jack and jacked it up the body right next to the rubber mount and the bushing slid right out. Now I'm off to the dealership this morning to buy a new body mount kit, I'll let you know how it goes.
I'm sure they will have to order the part, so this good take a couple of days.
dakrri
Old 05-17-2010, 05:46 PM
fordboy67's Avatar
fordboy67 fordboy67 is offline
fordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant future
Let us know if it took care of the noise, I have a similar noise and have been thinking of doing this.
Old 05-17-2010, 08:00 PM
Dakrri's Avatar
I bought the parts today, $110.00 for everything. The Tech at the Ford Dealership said I could reuse the bigger bushing/mount ($69.71) between the frame and cab, he thought it looked good yet. But Iím not taking that chance, there was a lot of wear/rust on the inside of the bushing. Funny thing....Ford now includes a shim in the kit and mentions that in TSB 10-7-3.
Iíll get the part tomorrow but I wonít have time to replace it until Wednesday night. Iíll let you know the results.
I'd like to post pictures but I don't see how I can....I didn't start this post maybe thats why???
dakrri
Old 05-17-2010, 09:58 PM
you paid 110 $ for both sides?
Old 05-18-2010, 09:08 AM
Dakrri's Avatar
No the $110.00 was just the drivers side.
dakrri
Old 05-19-2010, 12:30 AM
if you could take some picks of it with new shim i'd appreciate.
You can't post attachments cause you're not a supporter on FTE.
You think you could e-mail them to me?
Old 05-19-2010, 08:17 PM
Dakrri's Avatar
I'm still waiting for parts. I was promised by FORD they will be here tomorrow Ha-hmmmmm.
Now I can't make the repair untill Saturday, but i will take pics and get them on the site somehow
dakrri
Old 05-19-2010, 10:54 PM
thanx Dakrri.
Old 05-21-2010, 08:13 PM
Dakrri's Avatar
ZBIGBIG19TH I PM'd you, I put the parts in tonight and I need your email address so I can send the pics. I'd like to post them but I'm not a paying member.
The shim part number 1C3Z-10000145-AA, WAS $4.32
This took care of the cluncking. I did not have a foot pound wrench so i will be going back and torquing it tomorrow to 87lbs.
Thanks
dakrri
Old 05-22-2010, 06:17 AM
PM sent ,thanks again.
Body mount replacement ke6zmy Excursion - King of SUVs 3 11-15-2016 08:45 AM
Replacing Body Mounts? XC6.0 Excursion - King of SUVs 3 03-09-2016 06:33 PM
New body mounts Trapped_in_GNV 1999 to 2016 Super Duty 0 05-25-2014 09:49 AM
how to remove body mount bushing dieseldodgeguy 1973 - 1979 F-100 & Larger F-Series Trucks 5 07-28-2013 11:37 AM
Replacing Body Mounts jimbo285 1978 - 1996 Big Bronco 10 06-12-2011 11:19 AM
Tags
2000, 2001, body, bushing, cab, excursion, f150, ford, mount, mounts, mouts, ranger, replace, replacement, sd, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
