Exhaust manifold problems - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-18-2010, 08:47 PM
gmetime24 gmetime24 is offline
gmetime24 is starting off with a positive reputation.
I have a super duty 99 ford F250 V10 and have bolts on both sides that are broken off. They rusted out and fell off and some point and I would not be surprised if others fell off when they are replaced. I went to a local muffler man to have the muffler replaced and they are the ones who brought it to my attention. Muffler man told me they could fix both sides for around $800.00. I went to another mechanic to see what other estimates I could get and they told me they would have to lift my engine out of the car to get at the bolts and gave me and estimate around $2500.00!!! Does that seem right or do they not want to do the work?? Can this be done with the engine still in place?? Any advice would be great. Thanks
Old 03-18-2010, 09:16 PM
maddogken maddogken is offline
maddogken is starting off with a positive reputation.
i got a guy to do one side for $80.00
Old 03-18-2010, 09:23 PM
02mudbug 02mudbug is offline
02mudbug is starting off with a positive reputation.
it can absolutely be done with the engine in the truck. is seems that 600 to 800 bucks is what most people get quoted to fix this at private shops. If you pull the inner fender liner and the shock tower you have full access to all 20 studs. I am waiting for a weekend that the weather cooperates that im not obligated to help someone with something to install the ebay headers and remaining 16 studs and nuts on mine, I've already done the 4 that were broken off. Plan on having more of them break off, the key is several days of hitting them with penetrating oil before you try to get them out.
Old 03-19-2010, 12:32 PM
Ricohman's Avatar
Ricohman Ricohman is online now
Ricohman has a good reputation on FTE.Ricohman has a good reputation on FTE.
Can be done on your driveway with hand tools.
Took me a couple of days after work.
Old 03-19-2010, 01:30 PM
twall_SD250's Avatar
twall_SD250 twall_SD250 is offline
twall_SD250 is starting off with a positive reputation.
it defiantly can be done by anyone. i done mine yesterday in 1 1/2 days. i had 2 broken stunds and a crack exhaust manifold. all my bolts were rusted and corroded but i got lucky and not one broke off when i took it apart. like i said i did the whole job in a day and a half, just make sure befor you start spray the heck out of all the old bolts with BP Blaster and let it sit for a few hours if not overnight
Old 10-02-2010, 07:53 PM
F-7's Avatar
F-7 F-7 is offline
F-7 is starting off with a positive reputation.
Can someone tell me the best replacement studs for this problem. I am doing it next weekend and don't want to replace them and have to do it again! What size are they? Thanks in advance
Old 10-02-2010, 08:01 PM
brownie83's Avatar
brownie83 brownie83 is offline
brownie83 has a very good reputation on FTE.brownie83 has a very good reputation on FTE.brownie83 has a very good reputation on FTE.
when i did it on my 03 v10 i used flange bolts. i forget the actual size. if you search in the v10 forum, there should be a good thread about the size and how to do it. i used about 4 LEFT hand drill bits and flange bolts. cost me about 35 bucks and a weekend of work. good luck
Old 10-02-2010, 08:15 PM
F-7's Avatar
F-7 F-7 is offline
Thanks Brownie
Old 10-02-2010, 11:45 PM
99f350sd 99f350sd is offline
99f350sd has a good reputation on FTE.99f350sd has a good reputation on FTE.
I used the stock studs from ford which now are stainless steel...IMO I would use them as well as the stock nuts which are a mix of metals. I had to weld nuts on the broken studs to get them out with a mig welder...not fun but I got it done..NPI.
Dick
Old 10-03-2010, 09:19 AM
Boris2000 Boris2000 is offline
Boris2000 is starting off with a positive reputation.
Talking
Quote:
Dick
What Dick said! I had like 8 broken studs. Got them all out in less than 4hrs. Heat from the welder helps loosen the broken studs.
Old 10-03-2010, 03:47 PM
ak-angler's Avatar
ak-angler ak-angler is offline
ak-angler has a good reputation on FTE.ak-angler has a good reputation on FTE.
I believe the originals were SS, too. The new ones are just a different grade.
Old 10-03-2010, 04:15 PM
In 2003 they came out with the SS units before that they were steel..
Dick
Old 10-03-2010, 05:48 PM
ak-angler's Avatar
My '03 has at least seven broken studs right now. So... are you saying that these are the new, improved "stainless" studs?
I stand by my earlier statement. All of them are stainless, just different grades. But, in either case, it's irrelevant. Ford did change the studs at some point. The problem is that they're only marginally better than the originals. And, there's still plenty of reports of failures using the new ones.
Good Deed is getting over my head kramerpage 2004 - 2008 F150 23 02-13-2015 12:11 AM
2012 F350 6.2 DRW Exhaust the_justin 1999 to 2016 Super Duty 9 03-20-2013 08:36 PM
Stock manifolds or home-installed headers? Fish_Scientist 1973 - 1979 F-100 & Larger F-Series Trucks 4 04-15-2012 06:55 PM
OEM kitty delete...sorta zhilton 6.0L Power Stroke Diesel 20 01-01-2012 10:00 PM
Flange from CC to muffler broke. Request replacement part numbers rob_engineer Explorer, Sport Trac, Mountaineer & Aviator 1 07-18-2011 08:29 PM
Tags
07, 1999, 54, bolt, bolts, crack, duty, exhaust, f250, ford, labor, manifold, monifold, problems, rr, super, time, truck, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
